intake - EG with B16 ???
Which Air Intake (Cold) will fit. I know the one for the SOHC will fit, but the diameter is smaller.
So, will the one made for 99-00 Si will fit ?? or the one for the Type R ???
Thank you
[Modified by Beeline, 5:13 PM 7/5/2002]
Thank you
99-00 Si will fit, and also a Type R intake will fit. I've heard diff. stories
with the ITR intake about moving the overflow bottle, and have also heard
it fits w/o any problems.
type r= 3in dia.
fit good i have it on mine * goes beside the passager side wall. doesnt go in the hole .
99 si or del sol = i think 2.75 dia goes into the cold air of the org civic.
fit good i have it on mine * goes beside the passager side wall. doesnt go in the hole .99 si or del sol = i think 2.75 dia goes into the cold air of the org civic.
i've got a 99-00 civic SI intake on my setup. fits just fine, but rubs against my neuspeed upper strut bar. i'm sure you could use a different bar or none at all and everything would work just fine.
[Modified by dogpile5, 10:50 AM 7/5/2002]
im sure some of you have already these pics but oh well. heres my old setup in my old hatch. itr AEM cold air. it fits perfect. just rubs a little on the coolant resevoir tank. i guess i could cut the pipe a little shorter when i installed the bypass vavle.
Thank you to all.
I will go with the 99-00 Si one
Jeramy
[Modified by WykidEG, 2:29 PM 7/5/2002]
The ITR intake....does it fit on the stock throttle body? I'm thinking of upgrading my intake, manifold, and throttle body, but I was going to do them at seperate times. I was just wondering because I have to get rid of my shabby intake I have now so that was going to be the first to be replaced.
Tahnks!
Tahnks!
Tahnks!
Tahnks!
Jeramy
13sechatch
Southeast (Sales)
Aug 8, 2008 04:57 AM
