type r cams, cam gears, valvetrain.
Old Feb 21, 2008 | 01:18 AM
type-GGSR's Avatar
Default type r cams, cam gears, valvetrain.
My buddy just got his type r cams, cam gears, and valvetrain, type r intake manifold, type r throttle body, and the jdm itr ecu. Hes got a 96 gsr motor. Were planning on putting it in but, will this setup work? Also, will he need a tune for this, or will he be able to drive it as is? Its almost like getting a type r head isnt it? or am i just completely wrong? .. anyways, any help would be appreciated.
Old Feb 21, 2008 | 03:03 AM
dickdragon's Avatar
the im will definetly NOT work!
as for everything else, if installed correctly....it should!!
Old Feb 21, 2008 | 03:06 AM
type-GGSR's Avatar
Default Re: (dickdragon)
why would the IM not work? Also, with this setup, would he require a tune? Or could he just run on this setupd without getting one?
Old Feb 21, 2008 | 03:35 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (type-GGSR)
An IM designed for a PR3 head (ITR, CTR, B16A, B17) will not fit a P72 (B18C1)head. The cam gears and exhaust valves are the same as the GSR.
For the IM, you can get a Skunk2 or Blox, which are similar to the ITR IM.
Old Feb 21, 2008 | 03:40 AM
dickdragon's Avatar
tuning is good & recommended.
but not necessary.
hope that helps out a bit!
ELPITUDO
Jul 27, 2007 12:41 PM
solofthesouth
10
Dec 28, 2005 08:58 AM
Corinthians
Feb 13, 2005 10:50 AM
donnjuan2point2
Sep 16, 2003 12:15 PM
