AFC neo check engine light
Did you use a harness? or did you have to splice some wires and such?
Also make sure all your preset/setup settings are correct. And as long as you have everything zero'd out (tuning wise), you won't blow anything.
Munkyw3rkz.webs.com
like dumbass said....
i prefer the harness so the wires stay intact, ensure all the settings are set correctly (defaults)
I have a harness... and it was only letting me take it to 6 with every thing at zero and so i took it out and every thing is fine. the CEL went away
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">I have a harness... and it was only letting me take it to 6 with every thing at zero and so i took it out and every thing is fine. the CEL went away</TD></TR></TABLE>
Your settings are definitely wrong.
haha i did and i was messing with the values and it sounded like it was caming.
Im hoping its just a random miss fire cuz its -2 out side . Ill find out today I gotta pick some stuff up at a shop anyways they will just fix it for free or tell me how
just ran it and i came up with this
p0113 - air intake temp
p0118 - engine coolant temp
p-1415- air pump current sensor low voltage
p1259- vtec valve fault/ vtec switch fault open or short
na the codes went away and i put it back in and the codes came back. I figured out why and how to fix it so im on my way to do that now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">na the codes went away and i put it back in and the codes came back. I figured out why and how to fix it so im on my way to do that now</TD></TR></TABLE>
care to explain what you found?
i'm probably never gonna get an afc neo but others might have the same problems.
good luck!
good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey1320 »</TD></TR><TR><TD CLASS="quote">
good luck!</TD></TR></TABLE>
Its only cuz i dont have the instructions and I dont know what sensors to select
crapanese
16
Jan 1, 2017 07:33 PM
MrWestCoast
Mar 18, 2013 03:04 PM
kuja396
11
Apr 4, 2011 03:35 PM
skilla shut up i know your gonna say some thing dumb
