Seafoam... transmission?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAB18CR »</TD></TR><TR><TD CLASS="quote">has anybody used the transmission version of seafoam yet???
I personally wouldn't use it. I took my tranny apart at 80k and it looked perfectly clean on the inside. Trannsmission fluid can be used to *clean* your motor. So with this being said I'd imagine the tranny fluid breaks down most garbage in the tranny.
So I say the best thing for your tranny is to replace your fluid more often.
</TD></TR></TABLE>I personally wouldn't use it. I took my tranny apart at 80k and it looked perfectly clean on the inside. Trannsmission fluid can be used to *clean* your motor. So with this being said I'd imagine the tranny fluid breaks down most garbage in the tranny.
I changed my tranny oil about 350 miles ago, before I changed it for at least 30,000 and 5 years. The old tranny oil came out exactly like it went in in... same color, same weight, was not broken down one bit, I was shocked to say the least...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R »</TD></TR><TR><TD CLASS="quote">I changed my tranny oil about 350 miles ago, before I changed it for at least 30,000 and 5 years. The old tranny oil came out exactly like it went in in... same color, same weight, was not broken down one bit, I was shocked to say the least...</TD></TR></TABLE>
That has to be an exception. I've broken down fresh fluid over one weekend at the track. I know I'm not the only one either.
I guess conditions differ vastly after a track session compared to miles of street driving.
I changed mine last year b4 E7 and it had never been tracked. Fluid was super clean and the mileage was 31k.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">There is absolutely no reason to use seafoam in a honda transmission. </TD></TR></TABLE>
x2. There are no carbon deposits, moisture, and even air can't get in. It sounds like a gimmick that makes me question the legitimacy of seafoam made for engines..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 »</TD></TR><TR><TD CLASS="quote">
x2. There are no carbon deposits, moisture, and even air can't get in. It sounds like a gimmick that makes me question the legitimacy of seafoam made for engines..</TD></TR></TABLE>
im pretty sure air can get in there is breather on top of the trans
litterbox
Feb 11, 2005 06:13 PM
3000, 350, accord, allison, foam, good, honda, rewiews, safe, sea, seafoam, trans, transmission, transmissions, treatmenthonda
