Dsm 450's on a basemap with no turbo??
I have a set of dsm injectors that i want go ahead and wire up before i install the turbo related parts. will these injectors run smoothly with a basemap meant for 450's or should i wait till i can get it all tuned?
Yes, they will work fine. Just don't rev high enough to spool the turbo the basemap is for or they will inject too much fuel which can damage your engine. In short, yes it would be okay if you were careful, but only install them if you have a reason to.
After re-reading your post, you should not do it just because you're getting antsy to mod your car. Wait until you have everything. Plus stock ECU > basemap anyway.
i was under the impression that untill the map sensor saw boost using chrome, the ecu would only send enough fuel to run the engine like normal like there was no turbo there at all.
Right, you could run the 450cc injector basemap on your car before you turbo your car. But I wouldn't recommend it. I would just do it all at one time. No reason to upgrade the injectors until you have to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youdontneed2cams »</TD></TR><TR><TD CLASS="quote">ok thanks allot for the help guys, just smelling boost is addicting, but i must be patient.
good choice.
</TD></TR></TABLE>good choice.
