oil leak???
Old Feb 19, 2008 | 06:28 PM
jasony0630's Avatar
Default oil leak???
ill try to post up some pics later.
but on the right side of the block (around where the ps pump is) and below the head, the whole block was covered in oil...i was thinking it might have been the crank seal and i dont think that it's a head gasket....but i have somehow been leaking oil...i checked my dipstick today and it was bone dry (yes, i was scared)
any ideas about where this could be leaking?
oil is all over the PS pump side (right side if looking from the front) and it is all over that side of the oil pan too....
thanks in advance,
jason
Old Feb 19, 2008 | 06:48 PM
jasony0630's Avatar
bump
Old Feb 19, 2008 | 06:53 PM
93egSLEEPER's Avatar
Default Re: oil leak??? (jasony0630)
sounds like a crank seal to me. i had the same problem after i completed my swap... it got squished and folded over somehow. a valve cover gasket would have oil all over the side of the head as well.
Old Feb 19, 2008 | 06:56 PM
jasony0630's Avatar
yeah, i thought it may be the crank seal...
since it leaks somewhere close to the crank pulley and it catches on to the belt and gets flung all over the underside of my hood.
sorry about the noob question, but is there a gasket between the oil pump and the block?
Old Feb 19, 2008 | 07:00 PM
Default Re: (jasony0630)
there is no oil pump gasket just the seal. i am pretty positive it is your crank seal. jack it up and look and if there is oil in your pulley then its that seal.
Old Feb 19, 2008 | 07:01 PM
jasony0630's Avatar
ok, ill check it tomorrow....
IF it isnt, what else could it be?
oil pan gasket? head gasket?
Old Feb 19, 2008 | 07:04 PM
the only other thing it might be is the VC gasket where it goes over the cams leaking down.
Old Feb 19, 2008 | 07:06 PM
jasony0630's Avatar
ok man, thanks a lot...
ill check up on all that stuff tomorrow.
thanks again.
drsab2000
Aug 8, 2015 05:47 PM
TomCat39
Mar 14, 2015 05:58 PM
1SickEG
Jan 28, 2013 03:54 PM
C_R_X_V_T_E_C
Jul 24, 2007 03:45 PM
immalooser
May 17, 2006 03:27 PM
