Building a Type R Motor NEED HELP w/ what pistons to use w/ nitrous
Old Feb 19, 2008 | 02:49 PM
x8_andrew_8x's Avatar
Default Building a Type R Motor NEED HELP w/ what pistons to use w/ nitrous
I have a type r motor i have been building and im not sure what parts to use.
so far i have a fully built head by REV. Its shaved 7 thousandths. the cams im using are Stage 2 Skunk 2 cams. Now the problem i am having is if i put very high compression pistons are the valves going to hit the pistons. i want to put je 12.5:1 pistons but they dont make them for a type r motor but they make them for b16's and gsr's. i would need to have them specially made the guy told me. the highest compression for the type r motor that they sell is the 11.7:1 so if i bought these pistons am i going to run into any problems.. i plan on spraying a wet kit of 150 shot..
Old Feb 19, 2008 | 03:17 PM
mx621's Avatar
Default Re: Building a Type R Motor NEED HELP w/ what pistons to use w/ nitrous (x8_andrew_8x)
there is no specific type r forged piston. if you plan on that big of a shot i would go no higher than 11.0:1 maybee more like 10.5:1 ish., unless u plan on race gas. but then i have limited experience with nitrous, back in 03 i had a 90 shot on a bone stock dx ek hatch before i did the swap, lol.. just my .02 cents
Old Feb 19, 2008 | 03:25 PM
4GE4YA's Avatar
Domed pistons and nitrous don't work well together. I'm not saying nitrous doesnt like compression because the two work well together. You just need the flatest piston face that is feasible.I would do Arias( due to their low expansion design) 10.5:1 flat tops, mugen or similar head gasket and flat faced valves. Thats should bring you pretty close to 11.3-11.5:1 Should make good power on motor and scream on the nitrous.
Old Feb 19, 2008 | 03:26 PM
4GE4YA's Avatar
Come to think of it. You would probably need to do a seperate fuel system for that size shot. Just to be on the safe side, I would fill the seperate system with some 109-116 fuel.
Old Feb 19, 2008 | 05:16 PM
usdm type r pistons are already 10.5:1.. i dont really care about the nitrous part because ill run race gas when i spray but my main concern is the piston hitting the valves with a very high dome like above 11.7:1 and stage to skunk 2 cams
Old Feb 19, 2008 | 05:55 PM
skUnK2jdm's Avatar
Old Feb 19, 2008 | 05:58 PM
00Red_SiR's Avatar
All Motor Mentor
Let me ask you this.....WHY do you want a compression level that high? Why do you NEED to spray a 150hp shot?
Old Feb 19, 2008 | 06:24 PM
Default Re: Building a Type R Motor NEED HELP w/ what pistons to use w/ nitrous (00Red_SiR)
thats a really stupid question!! im building a motor to race the **** out of it im trying to find out my limits!
Old Feb 19, 2008 | 07:17 PM
mx621's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Let me ask you this.....WHY do you want a compression level that high? Why do you NEED to spray a 150hp shot?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x8_andrew_8x &raquo;</TD></TR><TR><TD CLASS="quote">thats a really stupid question!! im building a motor to race the **** out of it im trying to find out my limits!</TD></TR></TABLE>
hold on let get the popcorn before you guys start! ,lol. i must say nitrous and honda's are pretty unchartered waters. you never see or hear of any nitrous cars. nitrous just scares me for some reason, wierd
Old Feb 19, 2008 | 07:57 PM
Phil M's Avatar
Default Re: Building a Type R Motor NEED HELP w/ what pistons to use w/ nitrous (mx621)
wow......just wow....
Old Feb 19, 2008 | 08:14 PM
skUnK2jdm's Avatar
Default Re: Building a Type R Motor NEED HELP w/ what pistons to use w/ nitrous (Phil M)
who cares why he wants a high compression motor! and why he wants to spray
Thats like asking why do guys like girls with big ****!!
Old Feb 19, 2008 | 09:09 PM
Default Re: Building a Type R Motor NEED HELP w/ what pistons to use w/ nitrous (skUnK2jdm)
lmfao hahaha
Old Feb 19, 2008 | 09:20 PM
egb18c5's Avatar
i would like to know more about this too, hopefully cubish can put his .02 cents in. my friend is thinking on a build with 12.5 compression and 150 shot on c16 gas
Old Feb 19, 2008 | 09:24 PM
RC_Rikimaru's Avatar
use stock pistons just dont boost that much. if he makes it for gsr the then the r block is the same all is differant is the crank.
Old Feb 20, 2008 | 11:24 AM
Seminole's Avatar
spray and pray baby!
Old Feb 20, 2008 | 01:30 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil M &raquo;</TD></TR><TR><TD CLASS="quote">wow......just wow....
x2...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Don't worry, I'm sure you'll find that out real soon..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mx621 &raquo;</TD></TR><TR><TD CLASS="quote">
hold on let get the popcorn before you guys start! ,lol. i must say nitrous and honda's are pretty unchartered waters. you never see or hear of any nitrous cars. nitrous just scares me for some reason, wierd </TD></TR></TABLE>
Look in my sig....I run nitrous and drive a honda. I know lots of people that do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">
I was about to try and help him but it's obvious that he, as well as you and maybe others are more interested in big **** and eventual fireworks, than a well rounded package or a motor that not only makes great power but stays together too.
Old Feb 20, 2008 | 02:12 PM
4GE4YA's Avatar
For any of you that think hondas and nitrous are uncharted water, maybe you should talk to H-T member "nitrousballa" or maybe "GhostOfNyc. They will tell you just how uncharted it is.
Old Feb 20, 2008 | 06:20 PM
queda's Avatar
i want to run 12.1 compression but i only want to spray a 50 shot of nitrous
Old Feb 21, 2008 | 04:24 AM
saleensolution's Avatar
Default Re: (queda)
not here to judge on what you are doin. but correct me if im wrong, but couldnt you just get some pistons for the b16 with that compression? i mean the head is the same design as the type r as far as the combustion chamber right?
Old Feb 21, 2008 | 05:08 AM
IntegraType-R's Avatar
i sprayed my stock itr bottem end with a 75 / 100 shot.. CR wasn't as high as it is now but it was mid 11's.
Old Feb 21, 2008 | 12:31 PM
h22crxpwr's Avatar
Default Re: (IntegraType-R)
actually you would get more feedback if you posted in the FI forum. this is the all motor forum...
and i've sprayed 100 shot direct port on a stock LS block with no problems. tuned correctly nitrous is a great power adder.
people are just scared of it. they hear stories and believe everything they hear..
young geezer
May 17, 2010 09:30 AM
v-tech*killa*
Sep 18, 2007 08:10 AM
SHhh__VTEC
May 20, 2007 07:13 PM
SHhh__VTEC
Jul 12, 2005 07:06 AM
elmo244
May 30, 2005 12:57 PM
