is a 205 tire to big for a del sol?
Old Feb 19, 2008 | 05:27 AM
95dcGSR's Avatar
Default is a 205 tire to big for a del sol?
was wondering if a 205 series tire to wide for a del sol?
i see everybody run 195 series and want something alil wider? will it rub when i turn with this size on there...
im runnin a 15inch rota slipstream, and lowered 1.5inchs?
any thoughts
Old Feb 19, 2008 | 05:30 AM
crazyguy's Avatar
Default Re: is a 205 tire to big for a del sol? (95dcGSR)
195 sounds the right size. i am using 195 too
Old Feb 19, 2008 | 06:28 AM
nub's Avatar
nub
Default Re: is a 205 tire to big for a del sol? (crazyguy)
205/45/16 here rubs a little on the plastic inner fender up front when turnig and going up/down steep driveways if not careful with speed. the rear was kinda close to the lip of the wheel well so i rolled the lip to be on the safe side. other than that no probs.
Old Feb 19, 2008 | 07:18 AM
JSPECSIR's Avatar
Default Re: is a 205 tire to big for a del sol? (nub)
i run 205 40 17 on both my civics. wheel offset is 42mm. i dont have any rubbing. both cars are lowered.
Old Feb 19, 2008 | 07:20 AM
DelSolMarine's Avatar
Default Re: is a 205 tire to big for a del sol? (JSPECSIR)
i run 205/ 50/ 15's on gsr blades and i have NEVER rubbed... thats also because my muffler and the rest of my car arent dragging on the ground... 1.5 doesnt sound like enough to be tucking so you should be fine.
Old Feb 19, 2008 | 07:40 AM
spivt11's Avatar
* B A N N E D *
Default Re: is a 205 tire to big for a del sol? (DelSolMarine)
I run 205/45/R16 on my civic which is dropped the same 1.5'' and there is no rubbing, you should be fine.
Old Feb 19, 2008 | 07:59 AM
HONDACIVC93's Avatar
i run 215/50/15 on my 95 coupe, at least im almost positive its 215s, but i rub on sharp turns. im just gonna roll the fenders and i think ill be fine
Old Feb 19, 2008 | 08:11 AM
instrument's Avatar
205, i've never ruon 195's on any of my cars
Old Feb 19, 2008 | 09:21 AM
Panda Eg6's Avatar
Default Re: (instrument)
205 is fine, I ran 50/205/15 on both my del sol's slammed and didnt have any problems just a tiny bit of rub with the wheels all the way turned.
Old Feb 19, 2008 | 09:27 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (Panda Eg6)
You might want to get wheels with a bit different offset if you want full range-of-motion without rubbing
Old Feb 19, 2008 | 09:37 AM
Orangedragone's Avatar
205/50/15 on LS mesh on a Lowered Delsol.
No rubbing whatsoever. Pics if you want.
Old Mar 3, 2008 | 05:47 PM
Darknessezz's Avatar
im on 205/50/15's too heres some pics
Old Mar 3, 2008 | 06:40 PM
Bob Dole!'s Avatar
Default Re: (Darknessezz)
You'll be just fine I'm running 205/50/15's on +40 offset and i have no rubbing issues at all!
Old Mar 3, 2008 | 08:30 PM
Del Sol on Steroids's Avatar
205/40/16, and it rubs slightly. i say go 195
Old Mar 3, 2008 | 08:31 PM
BlueIntegraBoy's Avatar
I ran 205/50/15 and a +42 offset on my 92 hatch. There wasn't any rubbing.
Old Mar 4, 2008 | 08:03 AM
93blacksol4life's Avatar
I'm runing 205/ 50/ 15's on my delsol too
Old Mar 4, 2008 | 08:20 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: is a 205 tire to big for a del sol? (93blacksol4life)
im on 225\40r16 lowered 1.5 inches, no rubbing at all
Old Mar 4, 2008 | 09:37 AM
609CivicEx's Avatar
I had falken azenis 205/50/15's on my gsr, good grip no rubbing at all, it was pretty low also... you should be ok
Old Mar 4, 2008 | 09:59 AM
motorD16Y7's Avatar
Bump, show me some more pictures.
They all look good
Old Jun 7, 2018 | 12:06 PM
.94delslow.'s Avatar
what's the offset
Old Jun 8, 2018 | 02:35 AM
NVturbo's Avatar
O.G. triple O.G.
I'm on 205/50/15's on my Del Sol w/o any issues.
Old Jun 8, 2018 | 04:15 AM
Chance EG's Avatar
Originally Posted by .94delslow.
what's the offset
You bumped a 10 year old thread.
You would need a lot of offset for a 225 16in setup to fit. +35->+43 would likely be ideal.
Sylendrian
Jan 6, 2019 05:05 PM
TylerCJ7
Apr 20, 2013 01:30 PM
.BoostCreep
May 14, 2007 05:39 AM
delsol3982
Dec 29, 2003 08:48 PM
topher
Feb 25, 2002 07:03 AM
