kosei k1 question
New User
kosei k1 question
I am about to pick up a set of kosei k1 racings for my del sol
15" rims
my question is this
how wide a tire can I run, and is a 50 sidewall the right size for a sol on a 15"
I was thinking 205/50/15
or 215/50/15
whats the widest tire i can run on a 15" kosei
15" rims
my question is this
or 215/50/15
New User
Re: kosei k1 question (beeboyee)
but i want a wider profile
will a 205/50/15 be alright?
and as for the del sol
I know there are 2 offsets
a wider one and a narrower one
I want the one that makes the wheels stick out more
gives it almost a rally look
I am not concerned about being able to tuck the tires in the wheel wells
Re: kosei k1 question (topher)
I run 205/50 A032R's on the Kosei's and it works fine. some rubbing under extreme steering angles, otherwise no problems.
This is w/ a HB
This is w/ a HB
Re: kosei k1 question (KekeK_5G)
I run 205/50x15" Azenis tires on my 15x7" Kosei K1s. Just make sure you get 45mm offset and then get some 2-3mm spacers. Mine were hitting the rear upper control arms, but a 38mm offset would hit the fenderlips.
I have 205/50 15 Hoosier r3s03's on my 5th gen. with K1's(15x7 38mm offset). Work with a little "love" on the flanges. With any other tire, i'm sure they'll be fine. 195's look anemic on the car.
New User
Re: kosei k1 question (CivicSiRacer)
"45 mm offset is the one that sticks out a little better??"
no-the more offset(larger #) the more inboard it pushes the wheel. The closer to zero offset, the further out(typical rwd fitments are this way).
Good luck.
Good luck.
speedehatch
04-01-2004 05:17 PM
