95 del Sol on 225/45/15 ? STS2 Autocross
Ive found that Hankook has a Ventus R-S2 225/45/15 that I'd like to put on a 15x7 +41mm wheel. The car isnt dropped much, maybe 1.75" on Eibach pro springs, there is about 1.25 of negative camber in the front. The tire is approximately 23x9 with a 4" section height if that helps some of you drivers on slicks.
Will this wheel/tire combination fit in a 95 del Sol with or without rolling the fenders? I may be able to pull the fenders slightly, but big pulls and flaring is against the class rules. I'm trying to run as much tire as I can especially since I can go as wide as a 225 in class.
Here is the car on a pretty hard corner. I do have some tucking... the tires in the pictures are 205/40/17 on some ADR aluminum that weigh about 35lbs per corner !
Maybe the pic will help?
Azenis is a 200 treadware
Ventus is 240 treadware... it's also 20mm wider at just about the same height as the 205/50.
Sir, I only want to know if they will fit. I raced on Azenis last year and know they are a good tire. But, Azenis dont come that wide in a 15.
Re: (MAFDARK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAFDARK »</TD></TR><TR><TD CLASS="quote">
225/45/15 on my sol. Had to roll the fenders a bit.</TD></TR></TABLE>
Do you remember the offset and how wide the wheel is/was ? Thank you for time !
95dcGSR
21
06-08-2018 04:15 AM
itsmejto
07-13-2008 08:42 AM
