Help With Washer Fluid Pump
Old Feb 18, 2008 | 12:13 PM
Hater01's Avatar
Default Help With Washer Fluid Pump
OK so i just bought my First Car and its a 1998 Honda Civic Ex and my window washer Fluid pump Isnt working Like it doesnt run at all I dont know if its a Fuse or what it could Be Some help would Be awesome
Thanks
Old Feb 18, 2008 | 01:58 PM
994door's Avatar
Default Re: Help With Washer Fluid Pump (Hater01)
Did you check for a blown fuse? Check to see if the pump is getting 12v if it is and it's not working then it needs to be replaced.
Old Feb 18, 2008 | 02:35 PM
thesmogman's Avatar
Default Re: Help With Washer Fluid Pump (994door)
If you can't hear it then it's the pump. If you can hear the pump then the nozzles are plugged.
Old Feb 18, 2008 | 02:36 PM
thesmogman's Avatar
If you can't hear it then it's the pump or a fuse. If you can hear the pump then the nozzles are plugged.
SORRY FOR THE DOUBLE UP!!
Old Feb 19, 2008 | 07:47 AM
Hater01's Avatar
I cant hear the Pump Running and i Dont know what fuse it is cause there is no fuse case to show fuse location
Old Feb 19, 2008 | 07:58 AM
thesmogman's Avatar
Have you located the connector to the pump? If so being it is open to the elements the connector might have corrosion on it. Try to plug and unplug that connector a couple of times and see if that will do the trick.
If I get an 98 in today I will look for the fuse for you.
Old Feb 19, 2008 | 08:03 AM
Hater01's Avatar
Default Re: Help With Washer Fluid Pump (thesmogman)
Yea thanks man that would be awesome i have been look all day yesterday and today and came up with nothing
Old Mar 2, 2008 | 07:37 PM
tkordesh's Avatar
So, I was wondering what my next step might be. I just replaced the washer pump and still no go. I have checked the fuse as well and it looks good. I can not even hear the pump try to do anything. I am wondering if it's a power issue, what ways could I check that?
Thanks in advance,
Old Mar 2, 2008 | 08:11 PM
jax97hx's Avatar
Default Re: Help With Washer Fluid Pump (tkordesh)
who needs one anywayws that was like the first thing i pulled outta my car next to the stock airbox
loose it you dont need it. just keep your car clean
Old Mar 2, 2008 | 08:14 PM
ke98248's Avatar
Default Re: Help With Washer Fluid Pump (jax97hx)
Well, for functionalities sake!
Old Mar 2, 2008 | 08:25 PM
ifIexplode's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jax97hx &raquo;</TD></TR><TR><TD CLASS="quote">who needs one anywayws that was like the first thing i pulled outta my car next to the stock airbox
loose it you dont need it. just keep your car clean </TD></TR></TABLE>
Are you kidding me?
You live in Florida.
Go drive somewhere that gets snow and salty roads, Then tell me you dont need washer fluid.
Try checking your Underdash Fuse #26
My service manual says, Windshield wiper motor/windshield washer motor.
Its a 20A fuse.
Old Mar 2, 2008 | 08:30 PM
jax97hx's Avatar
Default Re: Help With Washer Fluid Pump (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">
Are you kidding me?
Go drive somewhere that gets snow and salty roads, Then tell me you dont need washer fluid. </TD></TR></TABLE>
Toushey!
Sometimes i forget that i live in a different climate
bakakuso2
Mar 24, 2009 03:04 PM
bhillier
Mar 3, 2009 01:12 PM
DB1_559
Nov 4, 2005 06:46 PM
bo0sted
Mar 8, 2004 07:54 PM
