CF hood question
if i want a CF hood what i need?
what kind CF hood is good? not too expensive and not bad CF
CF hood easy to open while you driving?
please give me some idea
What do you mean what do you need? All you need is the hood...but if you want to be extra careful buy hood pins. VIS is a good brand, standard price. It's not up to the hood whether it's easy or not to open, if you're hinge is hood on your frame then it should be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qqyycchh »</TD></TR><TR><TD CLASS="quote">if i want a CF hood what i need?
please give me some idea</TD></TR></TABLE>
if you want anything.... speak english
or if you don't wanna drill into it, i'd recommend getting some spacers that will incline the hood at the hinge point (the end closer to the windshield) to where it has a lesser chance of catching much draft under it, plus gives you better cooling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bentegrity »</TD></TR><TR><TD CLASS="quote">or if you don't wanna drill into it, i'd recommend getting some spacers that will incline the hood at the hinge point (the end closer to the windshield) to where it has a lesser chance of catching much draft under it, plus gives you better cooling.</TD></TR></TABLE>
and you can be mad jdm yo
aahh man. we went over this like a month ago. this "mod" does nothing for your car. just do the install correctly and you'll be fine. better cooling was estimated at like 10 degrees of under hood temp. can you really tell that big of a difference? i think not. i believe that somone did say that he was able to touch the strut tower because it was cooler.
not to mention the fact that it looks stupid. it is however almost as cool as the single wiper mod.
just measure and re-measure when you mount your latch. it won't pop open.
oldB18EF
25
Dec 11, 2002 02:21 PM
