1995 Civic Engine turns off
Old Feb 17, 2008 | 07:39 PM
berttheraider's Avatar
Default 1995 Civic Engine turns off
When driving my civic, after about 20 minutes, the check engine light flashes, and the engine turns off. I then have to wait about 15 minutes, and the car will turn on agian. Any ideas?
Old Feb 17, 2008 | 07:40 PM
DCSportEJ1Civic's Avatar
Default Re: 1995 Civic Engine turns off (berttheraider)
check you check engine light then report back
Old Feb 17, 2008 | 08:50 PM
musclehead954's Avatar
something is probably clogged.check your ecu like dcsport said! maybe too lean fuel/air mixture. or too heavy. or the spark plugs arent working.
Old Feb 17, 2008 | 08:53 PM
LSR-Abuser's Avatar
[QUOTE=berttheraider]When driving my civic, after about 20 minutes, the check engine light flashes, and the engine turns off. I then have to wait about 15 minutes, and the car will turn on agian. Any ideas?[/QUOT
My Eg did this.It was the dizzy. would start up and drive for about 15mins and then shut down.And check your main relay as well.
Modified by LSR-Abuser at 10:11 PM 2/17/2008
Old Feb 18, 2008 | 06:39 PM
Default Re: 1995 Civic Engine turns off (LSR-Abuser)
sorry, but what is a dizzy?
Old Feb 18, 2008 | 06:40 PM
Default Re: 1995 Civic Engine turns off (musclehead954)
is there an easy way to check the check engine light?
Old Feb 18, 2008 | 06:53 PM
2redstars's Avatar
go to autozone, or find the 2 pronged plug in the passenger kick panel, its not plugged into anything. stick a paper clip in it to jump the two sides. count the flashes, they will be long blinks, then fast ones. so if it does 3 long and 4 fast, thats 34.
hondapinellas
Aug 17, 2014 12:30 PM
raceadolf
Mar 26, 2014 01:23 PM
civicgeek133
Apr 11, 2006 06:34 PM
originalbadbob
Jun 24, 2004 10:17 PM
