damn LS/VTEC oil line trouble..
I can't get my SS Oil Line in the red AN Fitting...so i can screw the 2 pieces together....man the strand of the line keep getting barbed..it it won't slide under the Red AN Fitting..i'm so frustered.
vnt
vnt
twist the red an fitting over the hose counter-clockwise, not clockwise.
the bigger lines are easier to do i only use 6n line, but the trick is to get as clean a cut as poss, take electrical tape and wrap the end up tight, let it sit for a couple mins squeeze it so it stays round, then take the tape off........ it will slide right on w/ out getting stabbed by the frayed wire
cpforyou
Apr 2, 2004 09:42 AM
