Holes tapped through tubo OK???
Old Feb 17, 2008 | 12:01 PM
Servo's Avatar
Default Holes tapped through tubo OK???
I just received a brand new GT2860RS from ATP turbo. Upon inspection I noticed that inside the compressor & turbine housing I could see where external mounting holes had been tapped all the way through the housing. I just wanted to get a or on whether this is normal...
Looking down the inlet to the turbine, you can see the wastegate port and the holes tapped for the downpipe mounting bolts.
Looking down the outlet of the compressor you can see holes tapped for mounting the center section plate thing (whatever its called).
I just need someone to tell me this is normal or to tell me I need to send it back. Thanks, guys.
-Nathan
Old Feb 17, 2008 | 12:27 PM
Bailhatch's Avatar
Default Re: Holes tapped through tubo OK??? (Servo)
thats normal.
Old Feb 17, 2008 | 07:49 PM
Servo's Avatar
Any need to use hondabond or anti-seize when installing hardware?
Old Feb 19, 2008 | 03:48 PM
Servo's Avatar
Up for a little more info on these holes...
Old Feb 19, 2008 | 04:34 PM
Blind-Fashion's Avatar
nope.. little lock tight never hurts tho.
Old Feb 19, 2008 | 05:22 PM
hybridsol's Avatar
Default Re: (Servo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Servo &raquo;</TD></TR><TR><TD CLASS="quote">Up for a little more info on these holes...</TD></TR></TABLE>
I was supried to see it also, but it's ok
Old Feb 19, 2008 | 05:24 PM
JoePSI's Avatar
Default Re: (Blind-Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">
I was supried to see it also, but it's ok </TD></TR></TABLE>
I used teflon thread seal tape on my last turbo. never had an issue.
Old Feb 19, 2008 | 06:05 PM
*Boostwerks*'s Avatar
From a manufacturing standpoint, drilling all the way through the housing is less likely to produce a crack.
I wonder how much those bolts sticking up hurt flow/efficency though. I'm sure it's not much though considering every turbo I've seen has this.
Old Feb 19, 2008 | 06:35 PM
Servo's Avatar
Thank you for the responses, guys. Has anybody had issues with the bolts getting seized in the turbine housing? I'm considering the frequently seized exhaust manifold bolts. (But I guess that may be a factor of heat & moisture.)
Old Feb 20, 2008 | 04:05 PM
Default Re: (Servo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Servo &raquo;</TD></TR><TR><TD CLASS="quote">Thank you for the responses, guys. Has anybody had issues with the bolts getting seized in the turbine housing? I'm considering the frequently seized exhaust manifold bolts. (But I guess that may be a factor of heat & moisture.)</TD></TR></TABLE>
Use studs anywhere you can. But if you can't, at least use antiseize lube.
mike93eh2
Dec 29, 2008 09:21 AM
RNPoo7
Jan 7, 2005 09:54 PM
slowdx
Sep 28, 2004 08:08 AM
PM-Performance
Apr 4, 2003 04:49 PM
porch
Dec 14, 2001 05:07 AM
