Suspension & Brakes Theory, alignment, spring rates....
front lower Ball joint help...
Old Feb 16, 2008 | 05:09 PM
ZOMBIEKILLER's Avatar
Default front lower Ball joint help...
Is there a way to remove the front lower ball joint with out a special tool....
Old Feb 16, 2008 | 05:52 PM
pimpvw's Avatar
Default Re: front lower Ball joint help... (ZOMBIEKILLER)
a hammer
Old Feb 16, 2008 | 07:25 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZOMBIEKILLER &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way to remove the front lower ball joint with out a special tool....</TD></TR></TABLE>
You don't need any special tools. You just remove the retaining circlip and beat it out of the knuckle with a hammer.
Old Feb 16, 2008 | 07:40 PM
wed3k's Avatar
thats what i did...balljoint went flying across the shop so beware
Old Feb 17, 2008 | 12:04 PM
how you guys get the retaining circlip off it moves around
Old Feb 17, 2008 | 06:52 PM
wed3k's Avatar
with a retaining clip removal tool.
Old Feb 17, 2008 | 11:05 PM
AspectIndustries's Avatar
Default Re: (wed3k)
a Snap Ring Plier will be more like it. It can be purchased anywhere, literally. (autozone, hf, snapon, napa, etc)
But yea, a hammer will work Out and In..
Old Feb 19, 2008 | 10:55 PM
HKSuperSi's Avatar
i had the same problem w/ the balljoints. i recommend taking out the knuckle cause it will be easier, trust me i just went through it last week. u can use a regualr plier for the clip if your not going to use the clip anymore but i recommend getting a new one. as for pressing it back it back in, it will be a bitch so just take it to a shop to have them press it in makes everything easier. hope this helps.
Old Feb 20, 2008 | 10:22 AM
Bakeoff's Avatar
Using an air hammer makes it 10 times easier. When putting it back in, use a large socket to spread the force out, so you don't damage the new part.
Old Feb 21, 2008 | 09:51 AM
hybrid90's Avatar
Default Re: (Bakeoff)
When you guys put in the new ball joint, did you guys use a big socket and hammered it in from the top also or did you guys have to rent a ball joint press?
Old Feb 21, 2008 | 11:30 AM
Targa250R's Avatar
be professional
Default Re: (hybrid90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid90 &raquo;</TD></TR><TR><TD CLASS="quote">When you guys put in the new ball joint, did you guys use a big socket and hammered it in from the top also or did you guys have to rent a ball joint press?</TD></TR></TABLE>
If the knuckle is off the car, I just press in the joint with a socket and a bench vise.
If the knuckle is on the car, I beat it in with a hammer. You might be able to use a big C-clamp as well.
Old Feb 24, 2008 | 05:51 PM
I change the ball joints on my del sol to fix the steering problem I had it did fix it but the car feels like it has to much power steering an my car has no power steering I took it off.. Should I plug up those hoses from the power steering…? Or what’s the problem
Silent_Destruct
Jan 23, 2007 12:08 PM
skata89
Mar 30, 2006 06:41 PM
rasinhell
32
Jan 17, 2005 04:57 PM
2camsaam
Oct 2, 2003 07:30 AM
accordfreak
Jul 11, 2003 10:17 AM
