Ls Motor Swap
Old Feb 16, 2008 | 07:39 AM
Kingkoopa20's Avatar
Default Ls Motor Swap
Hey My wife drives a 94 Integra LS and it has that non-vtec b18 in it... which Ive heard is great for boost... sounds fun... I wanna drop my zc out and put hers in mine since its already paid for... only problem is shes got the automatic one.... will I be able to do the b2d swap and use the d16 manual tranny with the automatic ls motor?
I drive a 98 civic.
Old Feb 16, 2008 | 07:59 AM
Prism250's Avatar
Default Re: Ls Motor Swap (Kingkoopa20)
No, its not going to work. You cant put a D-series transmission to your LS motor.
Old Feb 16, 2008 | 08:11 AM
Well poop.
K thx...
Old Feb 16, 2008 | 08:38 AM
ltrkstr2k's Avatar
Default Re: (Kingkoopa20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kingkoopa20 &raquo;</TD></TR><TR><TD CLASS="quote">Hey My wife drives a 94 Integra LS and it has that non-vtec b18 in it... which Ive heard is great for boost... sounds fun... I wanna drop my zc out and put hers in mine since its already paid for... only problem is shes got the automatic one.... will I be able to do the b2d swap and use the d16 manual tranny with the automatic ls motor?
I drive a 98 civic.</TD></TR></TABLE>
why don't you just convert the Ls to 5-speed? (clutch flywheel etc)
Old Feb 16, 2008 | 08:43 AM
JDM-Riders's Avatar
A LS tranny would run you about 200-500, not a bad investment but I think you may need axles too, unless you can swap the axles on both cars...?
Old Feb 16, 2008 | 08:56 AM
ltrkstr2k's Avatar
Default Re: Ls Motor Swap (JDM-Riders)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-Riders &raquo;</TD></TR><TR><TD CLASS="quote">A LS tranny would run you about 200-500, not a bad investment but I think you may need axles too, unless you can swap the axles on both cars...?</TD></TR></TABLE>
thats what i meant about the clutch flywheel etc stuff. Im not sure if the auto axles and half shaft would work but it would be worth it. (if you ask me)
Old Feb 16, 2008 | 09:07 AM
Prism250's Avatar
Default Re: (ltrkstr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ltrkstr2k &raquo;</TD></TR><TR><TD CLASS="quote">
why don't you just convert the Ls to 5-speed? (clutch flywheel etc)</TD></TR></TABLE>
He an convert the motor by changing out the Intermediate shaft etc. But still his question was to make the motor work with a D16 transmission. Automatic or not that doesnt even matter anymore. B-series and D-series transmissions arent interchangeable, so he cant accomplish what he wants. What you can do is go buy a manual LS transmission and there you go.
Old Feb 16, 2008 | 11:43 AM
Is the manual LS a prefered choice? Or would the gsr tranny be better to just get? And these can bolt up to where the automatic tranny was?
Does LSD come with any choices?
Modified by Kingkoopa20 at 1:04 PM 2/16/2008
Old Feb 16, 2008 | 12:06 PM
CivicJockey's Avatar
im pretty sure all gsr and itr transmissions are LSD and I always heard that automatic axles and manual axles were different too. and you'll need to get a manual ecu. also, either fabricate the linkage or order the linkage that would hook up to your car and the B series tranny. basically there is quiet a few things you need to pick up first.
Old Feb 16, 2008 | 12:19 PM
justinCO's Avatar
Default Re: (CivicJockey)
GSR trannys are not LSD...an ITR is.
You'd probably want a GSR transmission, for performance, LS gears are longer. You'll pay more for a GSR though. Yes an LS or GSR manual tranny will bolt up to your LS motor.
Old Feb 16, 2008 | 12:24 PM
instrument's Avatar
if you thought a d series tranny would bolt up to a ls then you need to do a lot more reading.
may i suggest you try
really.
92civichatch1
16
Sep 16, 2005 05:27 AM
91hboySI
Sep 8, 2004 01:01 PM
i want a civic
Jul 27, 2003 03:11 PM
vtecsiqt
Jan 20, 2002 10:10 PM
