Head Gasket (Lowering Compression)
Old Feb 16, 2008 | 04:17 AM
ProjectBB6's Avatar
Default Head Gasket (Lowering Compression)
Something seriously embarrassing happened a couple days ago. Its looking like I am going to have to take the head off of my block. Since my car is turboed I thought it would be nice to shave a few degrees off the compression ratio. I also plan to buy a port and polished head from a friend which also comes with a port and polished intake manifold. Where can I buy a slightly thicker head gasket? Is this information correct: For every 0.01 you increase over stock thickness, you decrease compression 0.3? Thx
Old Feb 16, 2008 | 07:15 AM
contractkiller's Avatar
lower compression with pistons, not head gaskets.
Old Feb 16, 2008 | 07:20 AM
98vtec's Avatar
moderator emeritus
Default Re: (contractkiller)
you can do it with headgaskets if you want. Going a little thicker wont cause any damage. However, going with really thick gaskets can induce detonation and other harmful effects.
Cometic makes a "stock" thickness at .030 (stock is .026). I'm running a .051" which lowered my compression from 13.2:1 to 12.2:1.
Old Feb 16, 2008 | 10:00 AM
pentaq's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote"> However, going with really thick gaskets can induce detonation and other harmful effects.
Why is that?
Old Mar 12, 2008 | 04:01 PM
Toanz's Avatar
what brand head gasket are you running?
Old Mar 12, 2008 | 05:44 PM
lude98SH's Avatar
that measurement is done after it is compressed correct ?
Old Mar 12, 2008 | 10:56 PM
amalby's Avatar
Default Re: (lude98SH)
I think in a perfect world your head gasket should be .050. it gives you the perfect amount of room for advancing and retarding. thats is my option.
Old Mar 13, 2008 | 04:58 AM
mgags7's Avatar
Default Re: (amalby)
Leah, what happened to it dude?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amalby &raquo;</TD></TR><TR><TD CLASS="quote">I think in a perfect world your head gasket should be .050. it gives you the perfect amount of room for advancing and retarding. thats is my option. </TD></TR></TABLE>
o rly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote"> However, going with really thick gaskets can induce detonation and other harmful effects.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">
Why is that?</TD></TR></TABLE>
I'm thinking it has to do with increasing the size of the combustion chamber, which reduces quench, and therefore increases the chances of detonation, correct?
Old Mar 13, 2008 | 09:24 AM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm thinking it has to do with increasing the size of the combustion chamber, which reduces quench, and therefore increases the chances of detonation, correct?</TD></TR></TABLE>
greater quench distance is a less efficient combustion and can lead to detonation. Not always tho. But it is a variable.
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
melovesboost
Feb 18, 2007 07:27 AM
prdtr15
Sep 25, 2003 03:45 PM
p1ccoloz
Apr 21, 2003 09:41 AM
