Acura Intregra won't start....
Old Feb 15, 2008 | 12:51 PM
cordino's Avatar
Default H-E-L-P Acura Integra won't start....
Hi,
I own a 91 Acura Integra RS and after working just fine going to work it wouldn't start again at the end of the day. Battery is okay, Fuel pump is working. Starter is working.
I had the Distributor exchanged with a rebuild one ca. 3 months ago and when I took the cap off yesterday it looked like there was ash and charring around the push rod.
Anybody ideas about if it is indeed the Distributor or there might be other things going wrong? The last time my Distributor quit, there was loud metallic grinding because the bearing had gone.
Thanks for your feedback!!!!
c.
Old Feb 15, 2008 | 02:52 PM
thewrai6th's Avatar
Default Re: H-E-L-P Acura Integra won't start.... (cordino)
Pull a spark plug and check for spark while someone turns it over, hold the spark plug to a ground unless you'd like to be the ground
Old Feb 15, 2008 | 03:46 PM
DA_9's Avatar
Default Re: H-E-L-P Acura Integra won't start.... (thewrai6th)
white ash in the dizzy usually means it has said its last words. I had the experience.
Old Feb 15, 2008 | 05:48 PM
soysauce93integra's Avatar
Is the car turnning over? Just like other people said. I would check if you are getting spark from your plug wires. If its not that check if your plugs ae fouled. I used to have a Nissan Sentra and it had a little pin size hole in the wire and it didnt start. So that maybe it too.
Old Feb 15, 2008 | 06:52 PM
tekstyle's Avatar
Default Re: H-E-L-P Acura Integra won't start.... (soysauce93integra)
how do you guys check if the plugs are getting spark? isnt grounding the plug while someone starts the car kind of dangerous?
Old Feb 15, 2008 | 07:02 PM
thewrai6th's Avatar
Default Re: H-E-L-P Acura Integra won't start.... (tekstyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">how do you guys check if the plugs are getting spark? isnt grounding the plug while someone starts the car kind of dangerous?</TD></TR></TABLE>Dangerous, I don't think so. Painful, yes.
That's why I said touch it to the ground unless you want to be the ground.
Old Feb 15, 2008 | 09:36 PM
tekstyle's Avatar
i searched on google and came up with this:
http://tewarehouse.com/7-05931
will this work?
Old Feb 15, 2008 | 09:49 PM
VTEC_Du_Ma_Mai's Avatar
when you ground the spark plug, all you do is take a spark plug out of the car and then stick it into one of the wires, just like how it would go in the car, and hold it next to a bolt. have someone crank it and if you see spark then youre getting spark. make sure to hold the wire not the plug itself.
edit: i thought i was responding to the op, cuz i thought tekstyle was the op since he was asking about grounding the spark plug. so i guess this info goes to you tekstyle.
Modified by VTEC_Du_Ma_Mai at 10:59 PM 2/15/2008
halocore
Jan 8, 2010 04:20 PM
DelSlowmo
61
Feb 12, 2009 07:50 PM
sikwitit
Apr 10, 2008 05:53 PM
intgraCA
Jul 27, 2006 09:12 AM
reese
Sep 2, 2002 11:59 PM
