99si motor. o2 senors need new. so i buy 2 new ones but the one i have is a 5 wire and the
Old Feb 15, 2008 | 10:31 AM
orangeracer's Avatar
Default 99si motor. o2 senors need new. so i buy 2 new ones but the one i have is a 5 wire and the
i have a 96hx. with a b16a2 and the si ecu. it needs new o2s. i bought 2 but they are 4 wire. does anyone no if i need a 5 wire or a 4 wire. i have a 5 wire on it now.
Old Feb 15, 2008 | 01:17 PM
dcsports's Avatar
Default Re: 99si motor. o2 senors need new. so i buy 2 new ones but the one i have is a 5 wire and the (oran
bump
Old Feb 15, 2008 | 01:20 PM
I Shot 50 Cent's Avatar
i'd assume since you arent using the hx motor or ecu, there's no need for the 5 wire.
Old Feb 15, 2008 | 01:27 PM
blk92_d16's Avatar
Yeah, if you're using a P28 or P08 then the 5-wire isn't needed. Tell you what though, I would like to get ahold of that 5-wire cuz I'm running a D15Z1 (vtec-e) & P07 in my Ex coupe. I've got a CEL 41 that would probably go away with it. Hit mt up! Thx
Old Feb 15, 2008 | 03:25 PM
Default Re: (blk92_d16)
Do you guys no the wiring scamadics? or there is 5 wires and only need to hooked up to work right, do you no which four should be together?
Old Feb 15, 2008 | 11:36 PM
dcsports's Avatar
Default Re: (orangeracer)
bump
streetstylenperformance
Feb 26, 2004 03:28 PM
Feb 22, 2004 09:37 PM
egizzle8
Feb 16, 2004 10:09 AM
sherman
Mar 17, 2003 06:04 PM
