need some help
Old Feb 15, 2008 | 10:29 AM
tuffghst's Avatar
Default need some help
In the process of replacing my passenger side mirror. Not as easy as i thought. I can't get to the two lower screws and that panel covering them does not budge one bit. Is there anyway of doing this without taking my entire door apart?
Old Feb 15, 2008 | 10:48 AM
Jagan'92's Avatar
Default Re: need some help (tuffghst)
looks like you need to take off your door panel - search the prelude archives (door panel) to get the screw locations for removing it.
Old Feb 15, 2008 | 11:34 AM
ludekid4323's Avatar
Its really easy to take the door panel off dude
Old Feb 15, 2008 | 12:21 PM
JrSr2003's Avatar
yup its easy... just two or three screws and the rest is snap off...
Old Feb 15, 2008 | 02:35 PM
trrhondahead's Avatar
Default Re: need some help (Jagan'92)
theres ascrew at the door handle and a clip to remove the arm. a screw at the front probably plastic. a screw in the arm rest. pry out the window door lock switch (carefully) unclip the harness. star at the bottom with a wide flat head and pop the panel of and raise it off the window guide. ur done!
casper.hughes
Oct 12, 2008 06:33 PM
integracura
Dec 17, 2007 02:06 PM
nbcivic
Feb 25, 2006 04:14 PM
206civic
Jan 8, 2005 11:43 AM
babyviper97
Jan 10, 2003 05:14 AM
