window help!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 12, 2008 | 04:44 PM
casper.hughes's Avatar
Default window help!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok i have a 94 2 dr lx and i was wondering how u take the las out of the door if any one knows a site or has detailed instructions i would really apreciate it thanks
Old Oct 12, 2008 | 05:23 PM
Default Re: window help!!!!!!!!!!!!!!!!!!!!!!!!!!! (casper.hughes)
anyone???????
Old Oct 12, 2008 | 06:33 PM
fleetw00d's Avatar
You have to remove the inner door panel. If it is similar to my 90-93's, there are three screws (one in the door latch handle, one in the arm rest, and one at the upper front corner of the panel. Put the window down before starting. One the screws are out, remove the bezel around the latch handle, you'll have to detach the power door lock plug and detach the linkage to the latch. Pull the door panel away from the door (there are clips around the perimeter), the lift the panel up. You might have to remove the panel over the mounting for the side view mirror. Once the panel is off, you'll have to disconnect the electrical connectors for the window switches and courtesy light. Pull the plastic lining away from the front and back of the bottom of the door. There are two screws that attach the bottom of the glass to the regulator assembly. You might have to reconnect the power window switches to raise the window some to access the screws through holes in the door.
jruiz094
Apr 4, 2010 04:59 PM
fasterthanrayswrx
Jan 26, 2007 04:36 PM
C2daIzZle
Sep 8, 2005 10:01 AM
206civic
Jan 8, 2005 11:43 AM
babyviper97
Jan 10, 2003 05:14 AM
