gsr swap in eg, revs but sputters
Old Feb 14, 2008 | 07:01 PM
spgcuantik's Avatar
Default gsr swap in eg, revs but sputters
ok its a 95 gsr into a 93 eg hatch, EX harness, chipped ECU .....edelbrock intake mani stock TB, edelbrock fuel rail stock fpr, i just started the car it starts first crank, the idle is around 1000, when i try to WOT it stalls then dies....but if i open up the TB gradually it revs up. i checked my vacuums sprayed brake leen on it ,but when i spray by the TB where the gasket meets the intake manifold it drops down but not that much any help please this is my first swap need to get car running, sucks catching the bus to work
**************IM NOT THROWING ANY CEL********************
Modified by spgcuantik at 4:35 PM 2/16/2008
Modified by spgcuantik at 7:53 PM 2/16/2008
Old Feb 14, 2008 | 09:02 PM
spgcuantik's Avatar
Default Re: gsr swap in eg, revs but sputters (spgcuantik)
bump this up, any help would be appreciated
Old Feb 15, 2008 | 06:29 PM
spgcuantik's Avatar
upppppppppppppppppppppp
Old Feb 15, 2008 | 08:08 PM
DoWnfall's Avatar
edelbrock manifold is for boost my car is na atm (92cx with gsr) and when i slam on it at low rpms it takes a second. so either dont step on it when youre at low rpms or just boost it.
Old Feb 16, 2008 | 03:33 PM
spgcuantik's Avatar
bump this up ne more info would be helpful
Old Feb 16, 2008 | 05:39 PM
spgcuantik's Avatar
Old Feb 16, 2008 | 06:10 PM
spgcuantik's Avatar
Old Feb 16, 2008 | 06:54 PM
spgcuantik's Avatar
cmon no1 else had this problem b4?
Old Feb 16, 2008 | 10:44 PM
spgcuantik's Avatar
upppppppppppppppppp
Old Feb 16, 2008 | 11:05 PM
.I.Need.Money.'s Avatar
Chipped ECU? What ECU? What program?
You might be getting too much fuel.
Old Feb 17, 2008 | 02:39 PM
spgcuantik's Avatar
chipped ecu using skunk2 program
Old Feb 17, 2008 | 06:47 PM
spgcuantik's Avatar
upppppppppppppppppppppp changed my map sensor didnt do ****
Old Feb 19, 2008 | 08:09 PM
spgcuantik's Avatar
fixed it! but its jus runnin a lil rich...could it be because i have straight piping all the way to the back
Old Feb 19, 2008 | 08:19 PM
boosted92hatch's Avatar
Default Re: (spgcuantik)
if its one of those skunk 2 chips off ebay, they suck, i bought one and the car never ran right. get a p72 ecu and it will run 100x's better.
Old Feb 20, 2008 | 05:30 PM
spgcuantik's Avatar
ok ima try one of my friends ecu's see if it helps
junebuggez_92
Oct 16, 2013 04:29 PM
jjmose03
Mar 9, 2012 07:59 AM
ic3man19
Sep 10, 2008 06:22 PM
spgcuantik
Feb 23, 2008 06:21 AM
