B20 crv engine?
Old Feb 14, 2008 | 03:37 PM
924doorEG's Avatar
Default B20 crv engine?
I'm thinking about puting a B20 crv non vtec engine in my car because i heard a few people tell me it hits hard. the questions i have with it is what kind of tranny should i put on it for closer gears? a b16? and the other question is can i put a GSr intake mani on it?
Old Feb 14, 2008 | 03:40 PM
lluks_844's Avatar
Default Re: B20 crv engine? (924doorEG)
b16 and type r have the closest gears and you can not put a gsr intake manifold on it
Old Feb 14, 2008 | 03:43 PM
924doorEG's Avatar
cool thanks man, now can u tell me what ALL i need for the swap? im confused on what motor mounts and shift linkage to use.
Old Feb 14, 2008 | 03:48 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (924doorEG)
you can do a search for a swap info.. type R trans is your best bet due to the OEM LSD.. it was a night and day difference for my B20Z after having an LS trans
Old Feb 15, 2008 | 09:47 AM
lluks_844's Avatar
Default Re: (spock_rocker)
for the swap it depends on what car it is going in.
Old Feb 15, 2008 | 09:53 AM
smileycvc's Avatar
Default Re: (lluks_844)
A b16 transmission or R transmission would be the best for the B20. If you ever consider going B20 vtec throw in a block guard because the sleeves are a weakpoint. Also as the motor sits now make sure you dont go over the stock rev limiter for the B20 or you seriously run the risk of snapping a rod.
Old Feb 15, 2008 | 10:36 AM
.PLUMMM's Avatar
If the car is for daily driving and you want short gears, i'd go with the b16 transmission. Although they are both short, the ITR tranny is just killer on gas mileage. My close buddy had a 98 spec ITR swap in his 95 coupe, and he was getting around 250 miles per tank! So it really is as short as people say lol
Genocide-kary
Jan 18, 2009 07:05 PM
youdontneed2cams
Dec 18, 2007 09:15 AM
viet1337
Apr 10, 2007 09:51 PM
sergionuneschang
Apr 23, 2004 08:13 AM
kmf0211
Feb 20, 2003 09:37 PM
