man this sucks!!! low compression test results!!!
Damn man... Hope it works out. Nothing worse than a busted car.
Keep us posted on how the stealership handles your situation.
G/L
G/L
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie »</TD></TR><TR><TD CLASS="quote">your other cylinders are low too. I did a compression test a few days ago and came out between 227-234.</TD></TR></TABLE>
depends on the compression gauge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">
depends on the compression gauge. </TD></TR></TABLE>
x2... hope you get it all worked out
Compression test depend on a few things, but considering the other 3 cylinders were grouped closely it was probably the gauge or the way the test was done. Either way a 70psi drop is alot, the ticking makes it sound like a valvetrain problem. Good luck at the dealership.
GSR_hatch936
Apr 5, 2007 11:04 AM
