What would I need to install these?
Old Feb 14, 2008 | 01:08 PM
jdmjunkie86's Avatar
Default What would I need to install these?
This id a picture of what I have. What do you think I will need to do to install them? I know I am missing wiring but how do you go about wiring them up?
Old Feb 14, 2008 | 01:10 PM
spivt11's Avatar
* B A N N E D *
Default Re: What would I need to install these? (jdmjunkie86)
what kind of car are you wiring them to?
Old Feb 14, 2008 | 01:11 PM
Default Re: What would I need to install these? (spivt11)
1996 Civic Coupe EX
Old Feb 14, 2008 | 01:13 PM
2redstars's Avatar
is this a rally car?
Old Feb 14, 2008 | 01:16 PM
spivt11's Avatar
* B A N N E D *
You will need some type of wire to go inside the either to the fuse or to a switch. Try to find a one that goes to the fuse from another ek so that you can hook up your fogs to the fog switch in the car (which you will aslo need to locate should come off same car) this would make things cleaner, but you could just hook it up to a custom switch from like Autozone or somethin. If you do that you must have wire that taps into a power source in your ignition wires then goes to the switch.
ejoner's Avatar
Default Re: (2redstars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars &raquo;</TD></TR><TR><TD CLASS="quote">is this a rally car?</TD></TR></TABLE> No its not, those are optional fog lights for the 96-98 civics. Your going to need wiring which is easy, just look online for a universal fog light wiring diagram.
Old Feb 14, 2008 | 01:17 PM
-Gambit-'s Avatar
close.... 96-98 civic oem foglights. Looks like your just missing the on off switch and the wiring harness
Old Feb 14, 2008 | 01:19 PM
Default Re: (-Gambit-)
shouldn't be too hard? i was told an autozone switch might not work?
Old Feb 14, 2008 | 02:57 PM
JasonGhostz's Avatar
Default Re: (jdmjunkie86)
The OEM Foglight Kit includes Harnesses for the Interior (under the Steering Column) and Engine Bay. It looks like those are missing. I'm pretty sure Eran in the Lighting Forum can guide you along whatever path you need to take from here.
Best of luck!
JasonGhostz
cotorresgee
Apr 3, 2008 08:24 PM
michael_antoi
Oct 16, 2006 03:08 PM
92hybrid+
Sep 15, 2005 06:38 PM
RuthlessEF-9
Feb 15, 2005 02:42 PM
MickREXor
Oct 16, 2004 08:54 PM
