wastegate to small??
Old Feb 13, 2008 | 06:18 PM
418whpturboD's Avatar
Default wastegate to small??
ok so i have a t3/t61 turbo and i have a ebay 38mm wastegate.. i am not sure if it is goint to be to small or not... i have a 12 psi spring if that make any difference.. but let me know thanks
Old Feb 14, 2008 | 01:44 AM
quik sol's Avatar
size isnt, but quality might be an issue. Ebay wastegates are touch and go.
Old Feb 14, 2008 | 02:01 AM
DailyDriverCivic's Avatar
Default Re: wastegate to small?? (418whpturboD)
as long as it functions correctly, a 38MM WG should be fine, as was already mentioned, the ebay quality may be an issue, but I would be willing to give it a shot!
Old Feb 14, 2008 | 03:34 PM
Default Re: (quik sol)
ya i have had it for a year now and i was on my boosted d but with a t3/t4 57 trim and it was fine with 25psi with 75 shot of nitrous so im just going to try it and see how it goes...
Old Feb 14, 2008 | 05:03 PM
welfarepc's Avatar
the more boost you run the more efficient your WG is. a 38mm at high boost levels would be perfect (like stated)
if you are trying to run a low boost level then a larger WG might be for you.
id say give it a shot but watch out for creep
092eg6
Jan 27, 2010 09:29 AM
eg_21
Jun 21, 2009 05:58 PM
Speed Infliction
Jul 10, 2006 03:23 PM
slowteg550
Jan 1, 2006 08:06 PM
