new oil pump top line and pressure problems please help out last fix in the motor!!!
Old Feb 13, 2008 | 10:43 AM
vtibrazil's Avatar
Default new oil pump top line and pressure problems please help out last fix in the motor!!!
After assembling the motor the red light turned on and so we tested the pressure from the oil and it was barely nothing. So we ordered a new oil (top line) pump and a new oil filter nippon. After assembli9ng everyhting together we turned in the motor and the pressure at idle is at 15 psi and when reving the car it goes to 30psi. what could be causing this??? any thoughts. Man this is really stressing me out since the whole motor is ready everything is new and this seems to be my only problem....please really need help with this.
Old Feb 13, 2008 | 01:43 PM
Rocket's Avatar
Default Re: new oil pump top line and pressure problems please help out last fix in the motor!!! (vtibrazil)
Do you know your bearing clearances? Has the crank been reground? I am taking some guesses here.
Old Feb 13, 2008 | 01:48 PM
Aquafina's Avatar
No debris in the pickup?
Old Feb 13, 2008 | 02:55 PM
ChameleonDesignz's Avatar
if block was machined... did you cleaned it???
Old Feb 13, 2008 | 04:41 PM
vtibrazil's Avatar
Default Re: (ChameleonDesignz)
NEW CRANKSHAFT EAGLE
NEW STANDART ACL BEARINGS
NEW PISTONS
EVERYTHING NEW
WITH EVERYTHING NEW AND STANDART TIGHTENED TO FACTORY SPECS.
THE BLOCK WAS CLEANED. COULDN´T FIND ANY DEBRIS.
I HOPE THIS CAN HELP YOU GUYS ..MAYBE TO POINT ME TO THE RIGHT DIRECTION TO FIND THIS PROBLEM THANKS A LOT FOR THE HELP GUYS
Old Feb 13, 2008 | 04:52 PM
Rocket's Avatar
Default Re: (vtibrazil)
YOU MIGHT WANT TO CHECK THE PRESSURE RELIEF VALVE AND SPRING.
YOU HERE ME BOI!!
!!Você Ouve-Me!!
Old Feb 13, 2008 | 04:53 PM
Natural Aspirations's Avatar
Did you put the oil restriction back in the block? It is under the head gasket about a 12mm plug with an o-ring around it.
Old Feb 13, 2008 | 04:54 PM
Jared's Avatar
no oil squirters?
Old Feb 13, 2008 | 05:09 PM
mar778c's Avatar
Community Builder
Community Influencer
This a stretch but do you have the pick-up gasket? and is the pick-up clean?
Old Feb 14, 2008 | 05:08 AM
vtibrazil's Avatar
Default Re: new oil pump top line and pressure problems please help out last fix in the motor!!! (mar778c)
i will check the valve relief and spring. after i will check the oil pickup. I think the oil restriction was never removed at all.
today more bad news i took the car out to see if at least he mantained that low pressure but seems everything went wrong since the red light came on gain and stayed on so i put the car back in the garage.
and yes it has a pickup gasket but it is a thick one.
josh.davis723
Mar 2, 2016 07:14 PM
jonathan13
Sep 4, 2009 06:15 AM
Cpt Ben
Nov 11, 2007 07:54 AM
0evilEMPIRE0
Jul 21, 2004 07:50 AM
