TPS adjustment
With the new TB (AEBS 68mm) I installed my tps off an h22a tb. However I cant get it quite in spec. The car runs decent but its about .1 volts out of spec. I believe it was at around .65v vs .48 that it is supposed to be running at. The problem is i have no room for further adjustment, thats as far as I can turn it. On hondata it does however start at 0% throttle and ends at 99% WOT. I forget the WOT voltage, I know it was close to 4.5, which i know generally on most cars is about right, but on a honda im not sure if its exactly correct. Any ideas ?
If Hondata is telling you 0% shut and 99% wide open I'd be pretty happy with that.
I don't even bother measuring the voltages when I do mine, I just look at Neptune (set at the default voltages).
So what is the correct voltage for the tps? Im throwing a cel again after replacing it already once. Was off for about a month and a half then came back on. I just wanna make sure its not some wiring before i buy an omni power one.
chewyv
Engine Management and Tuning
Apr 17, 2017 07:19 PM
H22AMedina
Apr 3, 2002 02:54 PM
