HELP with broken axle!!!
Old Feb 12, 2008 | 03:11 PM
k3nnex's Avatar
Default HELP with broken axle!!!
can someone help me. i had to change my axle because the CV boot riped. as i was removing my axle and it broke apart. i got the axle out but the rear is still stuck in my tranny/intermediate shalf??? i tried prying it out but it wouldnt move at all. is this normal that its stuck there? and are there any techniques on removing the end of this axle. thanks
here are some pics:
Old Feb 12, 2008 | 04:23 PM
Jmumblez2001's Avatar
Default Re: HELP with broken axle!!! (k3nnex)
lol,that's funny
get yourself a big flat tip screwdriver and and stick it between the tranny and outboard or inboard joint i think it's called and it should come out. if you have no big screwdriver get a prybar but you get the idea
Old Feb 12, 2008 | 04:25 PM
hotrodaccord's Avatar
did you pull on it and break the boot?
Old Feb 12, 2008 | 04:30 PM
sickeswrx's Avatar
Default Re: HELP with broken axle!!! (Jmumblez2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmumblez2001 &raquo;</TD></TR><TR><TD CLASS="quote">lol,that's funny
get yourself a big flat tip screwdriver and and stick it between the tranny and outboard or inboard joint i think it's called and it should come out. if you have no big screwdriver get a prybar but you get the idea</TD></TR></TABLE>
i tried that and it didnt pop out. its like stuck in there
Old Feb 12, 2008 | 04:33 PM
sickeswrx's Avatar
Default Re: HELP with broken axle!!! (hotrodaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrodaccord &raquo;</TD></TR><TR><TD CLASS="quote">did you pull on it and break the boot?</TD></TR></TABLE>
nope, the boot was already ripped, so as i was removing the axle. as the axle was coming off some bearings feel out and i couldnt pry out that rear part. any other options i can do to remove that back part. when i push and pull that rear part i can feel it clicking, but it wont come out.
Old Feb 12, 2008 | 05:10 PM
Default Re: HELP with broken axle!!! (sickeswrx)
that;s the only way for it to come out, ya gotta keep trying at it, it's even in the helms manual be persistent @ it it will pop out and besides you won't hurt nothing, or you can be creative by tying a rope on the inboard shaft and pulling on it.
Old Feb 12, 2008 | 05:19 PM
sickeswrx's Avatar
hahah, we tied a rope and that didnt work. i guess well jack the car up higher and try prying the **** out of it tmr. thanks for the help
thanks for the advices everyone
Old Feb 12, 2008 | 05:24 PM
did you drain your tranny fluid before attempting to remove the driveshaft. just curious
Old Feb 12, 2008 | 05:27 PM
sickeswrx's Avatar
no i didnt. am i suppose to? this is on a 98 automatic accord. could that be the problem?
Old Feb 12, 2008 | 05:57 PM
savclaude's Avatar
It is going to leak transmission fluid.
Old Feb 12, 2008 | 06:04 PM
k3nnex's Avatar
Alright I'll try to figure out how to do that, will flushing the fluid help? Or is that just another thing I gotta do.
Old Feb 13, 2008 | 03:17 PM
k3nnex's Avatar
MISSION ACCOMPLISHED THANK YOU ALL FOR YOUR HELP!!!
What I needed was a little bit of frustration. I wedged a flat head and hammered it between the tranny and the axle. After a few angry swings the piece popped out!
PhantomPharter
20
Apr 4, 2012 03:14 PM
EG6_978
Mar 18, 2009 02:38 PM
k3nnex
Feb 12, 2008 05:20 PM
Blaze45
Apr 20, 2004 03:35 AM
No More Civic
Oct 18, 2002 11:41 AM
