help with broken axle!
Old Feb 12, 2008 | 03:32 PM
k3nnex's Avatar
Default help with broken axle!
can someone help me. i had to change my axle because the CV boot ripped. as i was removing my axle, it broke apart. i got the axle out but the rear part is still stuck in my tranny/intermediate shalf??? i tried prying it out but it wouldnt move at all. is this normal that its stuck like that? and are there any techniques on removing the end of the axle. TIA!
Old Feb 12, 2008 | 04:11 PM
polishedturd's Avatar
I like PIE
Default Re: help with broken axle! (k3nnex)
try prying with 2 prybars(or long flat head screwdrivers) on either side equaly. no that is not normal for the boot to rip off like that. next time you have to replace an axle do not try to pull it out by the shaft.
you will have to pry on the face of the axel using the transmission for leverage. make sense?
Old Feb 12, 2008 | 04:22 PM
k3nnex's Avatar
Blah we did try both sides at the same time, it won't budge. We did pry it using the tranny for leverage too.
Old Feb 12, 2008 | 04:38 PM
sickeswrx's Avatar
Default Re: help with broken axle! (polishedturd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd &raquo;</TD></TR><TR><TD CLASS="quote">try prying with 2 prybars(or long flat head screwdrivers) on either side equaly. no that is not normal for the boot to rip off like that. next time you have to replace an axle do not try to pull it out by the shaft.
you will have to pry on the face of the axel using the transmission for leverage. make sense?</TD></TR></TABLE>
the boot was already ripped, so when i pulled the axle out by the shaft it came right off and some bearings fell out. prying wont work. any other ideas?
Old Feb 12, 2008 | 05:16 PM
gsr dood's Avatar
Default Re: help with broken axle! (sickeswrx)
prybar, screw driver, chisel, anything to get some leverage...... come on man, this is easy stuffff
Old Feb 12, 2008 | 05:18 PM
Tizight's Avatar
Like everyone said use a prybar.
It should pop right now.
EDIT: Why won't prying work?
Old Feb 12, 2008 | 05:20 PM
sickeswrx's Avatar
Default Re: (Tizight)
maybe i need to jack the car up higher for more leverage. ill try prying it again tmr. thanks for the advices guys
grjr
Aug 23, 2012 04:12 PM
PhantomPharter
20
Apr 4, 2012 03:14 PM
k3nnex
Feb 13, 2008 03:17 PM
Feb 19, 2004 08:54 PM
Smashback
Apr 10, 2003 11:09 AM
