d15b swap car stalls out when throttle slightly open
Old Feb 11, 2008 | 05:43 PM
obuhmyuh's Avatar
Default d15b swap car stalls out when throttle slightly open
for those of you who just helped me get my car started i just ran into another issue or 2 or 3 haha. car starts up fine but idles kinda of weird and is throwing code 5 and 14? MAP sensor and IACV?? speedo stays at 15mph and when i let air into the TB the car starts to die and when its all the way open it dies out.
Modified by d[sick]sTeena at 8:35 PM 2/11/2008
Old Feb 11, 2008 | 06:28 PM
obuhmyuh's Avatar
Default Re: d15b swap car stalls out when throttle slightly open (d[sick]sTeena)
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i19.photobucket.com/player.swf?file=http://vid19.photobucket.com/albums/b157/floydforlife/P2110508.flv">
Old Feb 11, 2008 | 06:51 PM
obuhmyuh's Avatar
bumppppp
Old Feb 11, 2008 | 07:28 PM
obuhmyuh's Avatar
Old Feb 11, 2008 | 07:30 PM
Turbo O's Avatar
You first need to fix your CEL's, or else your the motor wont rev up all the way.
Plus it will make it easier to find out whats making your motor die out.
Its sounds like you may have an intake manifold leak.
Old Feb 11, 2008 | 07:38 PM
obuhmyuh's Avatar
Default Re: d15b swap car stalls out when throttle slightly open (Turbo O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo O &raquo;</TD></TR><TR><TD CLASS="quote">You first need to fix your CEL's, or else your the motor wont rev up all the way.
Its sounds like you may have an intake manifold leak.</TD></TR></TABLE>
easier said than done... i would say its an intake mani leak as well but i dont know how to check if its leaking, i dont have and vacuum gauges or anything like that... i took off my iacv and replaced it with my older one (better shape) and cleaned it and nothing... also when it died last time a ploom of white smoke came out of my TB
jdmray
Oct 20, 2007 10:23 AM
h22sedan
Jul 31, 2007 03:27 AM
93sidelsolvtec
Jan 25, 2007 05:37 PM
DsCivicEx
Nov 30, 2003 06:02 PM
hatch101
Jun 23, 2003 07:27 PM
