code 3, switched MAP but now no start?
Old Jan 20, 2007 | 10:45 PM
93sidelsolvtec's Avatar
Default code 3, switched MAP but now no start?
Code 3.
Car runs ok but no vtec. I took a different sensor off another throttle body but now it wont even start. I put the old sensor back on and it started again, but with code 3.
Car idles great. runs great up to 4k were it starts to bog. At 6k it gets loud as hell and acts like rev limiter.
Sensors are the exact same part number. The replacment one worked 100% a few weeks ago on another car.
Modified by 93sidelsolvtec at 11:59 PM 1/20/2007
Old Jan 20, 2007 | 11:50 PM
VRD^don's Avatar
Default Re: code 3, switched MAP but now no start? (93sidelsolvtec)
take off your TB and clean it....
Old Jan 21, 2007 | 07:36 PM
Default Re: code 3, switched MAP but now no start? (k_motor)
It will start with the old sensor on there but not with the new one. I know this new one works because I just took it off a working car. Same part number and everything.....
Code comes on about 4 seconds after the car starts.
I cleaned the throttle body this morn.
Old Jan 22, 2007 | 09:56 AM
thesmogman's Avatar
Check you vacuum lines and the "tee's" sometimes they get plugged up.
Sometimes the map sensors look the same but the connectors inside are swapped.
I know you said they are the same part number, but that P/N might be for the case, not for the whole thing.
Map's are easy to check, get out the voltmeter!!
Also push the wires (from the backside of the connector) into the map while you have it connected you might just have a bad connection.
Old Jan 25, 2007 | 05:37 PM
Woot its fixed. I found that the map on the firewall didnt have a vacuum hose to the manifold. Laughing Laughing Laughing Laughing Laughing Laughing Laughing
I bought a hose and bam 100% h22 power
Gabe Gamble
Aug 7, 2011 03:26 PM
collin-eg2
May 18, 2011 06:30 PM
93sidelsolvtec
Jan 28, 2007 11:58 AM
WickedWerx
Oct 28, 2004 07:02 PM
