Bad Blowoff?
Old Feb 11, 2008 | 05:06 PM
roachsboosted16's Avatar
Default Bad Blowoff?
my blowoff sounds like a rattlesnake, which i kno is bad, but when i lossen the spring it does nothing, is the blowoff bad or is this only bcuz im running low boost?
Old Feb 11, 2008 | 05:17 PM
Default Re: Bad Blowoff? (roachsboosted16)
Old Feb 11, 2008 | 06:05 PM
melovesboost's Avatar
what blow off valve are you running? if you can take it apart and there are 2 springs some people remove the small spring
Old Feb 15, 2008 | 09:08 PM
.PLUMMM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 &raquo;</TD></TR><TR><TD CLASS="quote">my blowoff sounds like a rattlesnake, which i kno is bad, but when i lossen the spring it does nothing, is the blowoff bad or is this only bcuz im running low boost?</TD></TR></TABLE>
There are a lot of different Blow Off Valve's that make a lot of different sounds. Just because yours sounds like a rattlesnake doesn't mean it is bad. It could just be the type of Blow Off Valve you have. What brand is it?
swatteamtimmah
May 16, 2006 11:13 PM
s1ngle
May 28, 2005 08:59 PM
turbotypeR@SPEC
Nov 29, 2004 05:36 PM
ActiveAero
Jul 18, 2003 11:06 AM
