will a 92-95 head vtec head fit on a 96-2000 block ?
im building a turbo charged single vtec and im wondering if i can use a 92-95 vtec head on my 97 or 2000 block and will it be better .i keep saying 97 - 2000 cause i have two blocks wich one should i use
Assuming both are d-series parts, then yes, you can do that. In this case, the blocks are probably almost identical. If you can tell us the engine code on the front, we can help you better.
Search "mini-me".
Search "mini-me".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_4dr »</TD></TR><TR><TD CLASS="quote">is that a direct bolt up? isnt there an oil passage that needs to be modified?</TD></TR></TABLE>
Not in a d16y block
Not in a d16y block
For a boosted application, I'd recommend the Z6 block over the Y8. Especially for it's oil pump problems; but that can be corrected with a correctly ported pump. For the heads, the cc of the Y8 is a tad bit different, but nothing major. So Z6 block & Z6 head,Y8, or even a JDM D15b.
