Mini Me d15b8 w/ d16y8 head... Please help?
Old Aug 11, 2003 | 08:37 PM
SpydermanGS-T's Avatar
Default Mini Me d15b8 w/ d16y8 head... Please help?
We have a 97 EX that needs the bottom end rebuilt...So until this is finished we want to put the y8 head on a d15b8 block and tranny...Does any one have any info on this or is it a simple head on block swap..I've heard that there is a oil line needing to be drilled into the block...any info would help...Thanks
Old Aug 11, 2003 | 08:43 PM
The Brown Kid's Avatar
Default Re: Mini Me d15b8 w/ d16y8 head... Please help? (SpydermanGS-T)
nope just ta ke the oil contrlol jet out. and thats it. Thats prolly what you thought the drilling was.
Old Aug 11, 2003 | 09:05 PM
Default Re: Mini Me d15b8 w/ d16y8 head... Please help? (The Brown Kid)
Ok is there a place on the d15 block to plug it into?
Old Aug 15, 2003 | 06:20 PM
BMacls's Avatar
you are think of the b series motors. for sohc all you have to do is take out the oil jet and bolt the head to the block.
Old Aug 15, 2003 | 10:55 PM
PHiZ's Avatar
Default Re: Mini Me d15b8 w/ d16y8 head... Please help? (SI_CRX_AUTOX)
Someone said you had to block off an oil passage, is that what you're talking about?
-PHiZ
Old Aug 16, 2003 | 11:49 PM
BMacls's Avatar
Default Re: Mini Me d15b8 w/ d16y8 head... Please help? (PHiZ)
just take out the oil jet and bolt it up man and you are good to go.
Old Aug 17, 2003 | 10:40 AM
sweet thanks guys this really helped alot!
Old Aug 22, 2003 | 01:58 PM
jdmsiR20's Avatar
please correct me if i'm wrong, but the b8 is and 8valve, right? if you're running a 16valve head, there should be reliefs on the pistons for the extra valves... or is piston-valve clearance negligable?
Old Sep 22, 2003 | 09:04 PM
Ignitecivic's Avatar
Default Re: Mini Me d15b8 w/ d16y8 head... Please help? (jdmsiR20)
i have heard the all d15 pistons are the same, only the head are different.
Old Sep 24, 2003 | 02:39 PM
FMIDRC Racer's Avatar
Default Re: Mini Me d15b8 w/ d16y8 head... Please help? (Ignitecivic)
where is the oil jet that needs to removed? anyone have any pics?
Old Sep 24, 2003 | 04:04 PM
Default Re: Mini Me d15b8 w/ d16y8 head... Please help? (FMIDRC Racer)
its between cylinder 2 and 3 u will see it.
http://crx.honda-perf.org/arti...t.jpg
Old Sep 24, 2003 | 04:20 PM
i'd much rather have a pic. and how do i get it out? i have never had a piston engine apart before. what if i don't take the oil jet out?
Old Jun 23, 2004 | 10:44 AM
VRD^don's Avatar
what about the timing belt..y8 belt..z6 belt..
Old Jun 23, 2004 | 11:05 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">please correct me if i'm wrong, but the b8 is and 8valve, right? if you're running a 16valve head, there should be reliefs on the pistons for the extra valves... or is piston-valve clearance negligable?</TD></TR></TABLE>
AFAIK, the valve reliefs are all wrong.
Old Jun 23, 2004 | 11:11 AM
VRD^don's Avatar
Default Re: Mini Me d15b8 w/ d16y8 head... Please help? (sohc_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_vtec &raquo;</TD></TR><TR><TD CLASS="quote">what about the timing belt..y8 belt..z6 belt.. </TD></TR></TABLE>
come on i need to know..
Old Jun 23, 2004 | 11:44 AM
onePOINTsix's Avatar
ok the D15B6 is the 8 valve block (i know because i have one) but if their is another 8 valve block out there then you have to use D15B1,2,7 pistons. if the pistons on your block look like this then you need to use new pistons:
jwaggz21
Dec 6, 2012 11:22 AM
redline808
Apr 15, 2009 07:27 PM
slickrickauto
Sep 6, 2007 03:41 PM
boostedteg
Nov 2, 2002 10:25 PM
