99' DX Hood latch (any alternative ways to pop hood?)
Old Feb 11, 2008 | 05:31 AM
jbrez1886's Avatar
Default 99' DX Hood latch (any alternative ways to pop hood?)
So, its been sub-zero all weekend and I let my car sit, now I can't get my car started.....started to crack normally and then started to slow down more and more until I got nothing. I'm assuming I can get it started with a jump but I can't get my hood popped. I know there is a problem with the latch/cable system on 99' civics. I have unfortuantely suffered from this problem. For a while, I could use plyers to pull on the cable and pop the hood. For the last couple months I have not been able to open the hood this way. Are there any alternatives to popping my hood? I have read that I can open the hood latch with a flathead screwdriver, anyone have any insite? I have an OEM si grill so I can fit a screw driver near the latch pretty easily. any help is greatly appreaciated !
Old Feb 11, 2008 | 05:39 AM
pdiggitydogg's Avatar
Yeah...this is a shady post for a first timer...
Crawl under the car, mark where the latch bolts, remove the entire latch.
That is by far, the hardest way, but with all the honda theft there is...its the only one I feel comfortable telling you
Old Feb 11, 2008 | 06:04 AM
jbrez1886's Avatar
Default Re: (pdiggitydogg)
ok , well I know that is not the easiest way to open my hood, I''m not a dolt
I apprechiate teh fact that you are trying to avoid honda theft, but I am in a jam here, I don't want to pay 85 dollars to have my car towed just so I can have my hood popped and get a jump. Any help ? any way to prove this is not theft ? Print screen from geico?
Old Feb 11, 2008 | 06:47 AM
jbrez1886's Avatar
Default Re: (jbrez1886)
so i looked in the service manual and found the hood latch assembly, it looks like there is the latch and a striker? can anyone confirm this, it looks like the striker has to be pushed in the then it looks like I could slide the latch left.....is this correct?
Old Feb 11, 2008 | 07:00 AM
ifIexplode's Avatar
Just jack the front of your car way up in the air and take the whole latch assembly off.
Old Feb 11, 2008 | 07:06 AM
jbrez1886's Avatar
Default Re: (ifIexplode)
there is no easier way? or is this just a " do it the hard way to avoid theft" post
Old Feb 11, 2008 | 07:12 AM
ifIexplode's Avatar
I myself dont know about any easy way.
i had to replace my hood latch cable and I made the unholy idiotic mistake of cutting the cable and shoving it up into the firewall where it got stuck.
With my hood still being closed. So i jacked my car way up in the air and took the 2. or maybe its 3 1omm bolts off to take the whole latch off.
Old Feb 11, 2008 | 07:53 AM
instrument's Avatar
have you tried having someone pull the cable while you push down on the hood?
you may have to remove the splash guard and find that cable nearer to the latch and pull on it.
Old Feb 11, 2008 | 08:38 AM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbrez1886 &raquo;</TD></TR><TR><TD CLASS="quote">there is no easier way? or is this just a " do it the hard way to avoid theft" post</TD></TR></TABLE>
Just take the interior kick panel off on the inside by the hood release and that should give you enough room to get some pliers on it to give it a good tug. Then drive to your dealership buy the $15 hood release cable and replace it.
Old Feb 11, 2008 | 08:44 AM
saywhat's Avatar
Default Re: (saywhat)
Or better yet, read this, and come to your own conclusion you sketchy SOB... http://causeforalarm.thecarthi....html
Old Feb 11, 2008 | 11:27 AM
jbrez1886's Avatar
thanks, your maturity is shining right now
problem solved, car is running, none of these comments were useful, whats the point of a forum if everybody is negative? , mods close this thread
Old Feb 11, 2008 | 12:13 PM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbrez1886 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, your maturity is shining right now
problem solved, car is running, none of these comments were useful, whats the point of a forum if everybody is negative? , mods close this thread</TD></TR></TABLE>
Dude I totally showed you how to do it, that link has all the information. Don't be a hater...
haggecha
Honda Civic (2006 - 2015)
Jan 11, 2019 04:23 AM
FritschDog
22
Mar 31, 2017 08:41 AM
jmacsss
Apr 14, 2011 06:50 PM
rustboy
Feb 16, 2004 06:26 PM
