Question about clutch engagment
Old Jul 3, 2002 | 04:18 PM
EKen9's Avatar
Default Question about clutch engagment
I just got done putting in my swap and I installed an Exedy clutch and flywheel. When I started to drive the car i noticed that the clutch doesnt engage until the pedal is almost completely up. Anyway I can fix this?
Old Jul 3, 2002 | 04:35 PM
TurBoXBirD16's Avatar
Default Re: Question about clutch engagment (EKen9)
i would like to know also
Old Jul 3, 2002 | 09:14 PM
Mista Bone's Avatar
D Tranny Guru
perfectly normal on a hyd. clutch setup.
Old Jul 3, 2002 | 09:17 PM
maxim's Avatar
Default Re: Question about clutch engagment (Mista Bone)
Mine does that also. I have a Clutchnet StageII.
You can adjust the clutch engagement pedal with a screw on the master cylinder.
The high engagement is actually better since it helps to prevent missed shifts. I would leave it alone.
Old Jul 4, 2002 | 02:34 AM
Default Re: Question about clutch engagment (maxim)
good reason to keep it that way
thanks
Old Jul 4, 2002 | 11:04 AM
EKen9's Avatar
Default Re: Question about clutch engagment (xbird)
cool thanks for the help, it's gonna take some getting used to
Old Jul 4, 2002 | 11:13 AM
LshatchTurbo's Avatar
New User
Did you bleed the system correctly? It sounds as if you didnt bleed the clutch system good enough. And this is a upgrade clutch correct?
[Modified by lshatchturbo, 12:14 PM 7/4/2002]
Old Jul 4, 2002 | 11:14 AM
EKen9's Avatar
Default Re: Question about clutch engagment (lshatchturbo)
Yeah I'm gonna bleed it again today just to make sure.
Stonage07
Mar 6, 2017 11:48 AM
supersilverdc2
Transmission & Drivetrain
11
Jan 16, 2014 12:45 PM
Dre_559
May 28, 2009 08:23 PM
vinceg143
Sep 11, 2008 06:43 PM
blk97lude
Apr 12, 2003 06:48 PM
