Honda S2000 Honda S2000
Diff. drain bolt partly stripped.... need some advice
Old Feb 10, 2008 | 01:43 PM
Agent Zero's Avatar
Default Diff. drain bolt partly stripped.... need some advice
So today I changed my tranny fluid (RP syncromax, good **** so far) and went to change my diff. Well the stupid *** drain bolt is partly stripped. I can't seem to get a good bite on the bolt. Any suggestions??? TIA
AZ
Old Feb 10, 2008 | 02:42 PM
Agent Zero's Avatar
Default Re: Diff. drain bolt partly stripped.... need some advice (Agent Zero)
Here is a pic of the bolt.... It isn't all the way stripped but when I got up close to it, it looked like someone used a bootleg socket.
Sorry about the bad quality, the car is off the jackstands now and that was the best I could do with the car on the ground. Please help a brotha out... lol
Old Feb 10, 2008 | 02:46 PM
20ls01's Avatar
you should still be good as long as you use METRIC SOCKETS. dont use those adjustable wrenches or american readings. Plus, that nut doesnt look too bad. if your socket wont fit, hammer it in(it will straighten the stripped bolt)
Old Feb 10, 2008 | 03:30 PM
Agent Zero's Avatar
Default Re: (20ls01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">you should still be good as long as you use METRIC SOCKETS.</TD></TR></TABLE>
Dude... I am not that damn dumb. That is all I pretty much have is Metric. But I will try the hammer trick and see how it works.
Old Feb 10, 2008 | 03:39 PM
mrtrinh's Avatar
get a new bolt?
stupidwhitecat's Avatar
Default Re: (Agent Zero)
These have worked well for me in the past.
http://www.sears.com/shc/s/p_1...+bolt
Old Feb 10, 2008 | 04:55 PM
Agent Zero's Avatar
Default Re: (mrtrinh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtrinh &raquo;</TD></TR><TR><TD CLASS="quote">get a new bolt?</TD></TR></TABLE>
Thank you Capt. Obvious.... I can't get the old one out.
Old Feb 10, 2008 | 04:56 PM
Agent Zero's Avatar
Default Re: (stupidwhitecat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stupidwhitecat &raquo;</TD></TR><TR><TD CLASS="quote">These have worked well for me in the past.
http://www.sears.com/shc/s/p_1...+bolt</TD></TR></TABLE>
Looks like it only goes to 19mm. I need 24mm.. Thanks for the link though.
Old Feb 11, 2008 | 09:06 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent Zero &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you Capt. Obvious.... I can't get the old one out. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent Zero &raquo;</TD></TR><TR><TD CLASS="quote">
Dude... I am not that damn dumb. That is all I pretty much have is Metric. But I will try the hammer trick and see how it works. </TD></TR></TABLE>
why are you insulting people trying to help you out? If you knew everything allready what's the point of the post?
You know what size socket you need. Use a 6pt. socket (DUHHHH THAT'S OB-OB-OBVIOUS). So just go out and try it. There's not many suggestions here.
You use a wrench with a socket. Then you turn the wrench to the left. That's really the only suggestion.
Old Feb 11, 2008 | 09:16 AM
BoostLE's Avatar
Get a new bolt before you try to remove that one. You may strip it worse trying to get it out and then can't tighten it...
Old Feb 11, 2008 | 09:41 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">you should still be good as long as you use METRIC SOCKETS. dont use those adjustable wrenches or american readings. </TD></TR></TABLE>
i can't believe these 2 turds seriously said that
Old Feb 11, 2008 | 11:57 AM
joey1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
i can't believe these 2 turds seriously said that</TD></TR></TABLE>
wow i can't believe you 2
first Agent Zero, you come here asking a stupid question on how to remove a stripped bolt, and then you insult the people that try to help you out, what a dick... you know what, to hell with your stripped bolt; i hope it snaps when you are trying to get it loose and then you'll be f'ed trying to get it off the diff!!!
and grat-fiti come on man, those 2 guys gave good advices, to someone who they probably thought was a noob who didn't even own a good set of tools... why do you gotta jump in on somebody elses thread and put down the people trying to help???
Old Feb 11, 2008 | 12:04 PM
HondaKyle's Avatar
Default Re: (joey1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey1320 &raquo;</TD></TR><TR><TD CLASS="quote">
and grat-fiti come on man, those 2 guys gave good advices, to someone who they probably thought was a noob who didn't even own a good set of tools... why do you gotta jump in on somebody elses thread and put down the people trying to help???</TD></TR></TABLE>
well how would you fix it smarty pants
Old Feb 11, 2008 | 12:10 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (HondaKyle)
are you really 27 years old but refer to yourself as "joey"? seriously...time to grow up joseph
second, if these noobs posted a blatantly stupid response, as they did, they deserve to be notified that their input was crap....regardless if they thought agent zero himself was a noob
for you trying to play captain save-a-ho
Old Feb 11, 2008 | 12:17 PM
joey1320's Avatar
Default Re: (GRAF-FITI)
for you trying to play captain save-a-ho</TD></TR></TABLE>
muhahahaahahahaahahaha you can't be serious right???
i have an opinion and you start bashin' my age and nickname????????
hahaha thats freaking ridiculous...
and you call yourself graf-fiti??? i was actually doing grafitti back in the 90's when i was on my teens and grew out of it... lol. anywas i'm 27 years old and my nickname is joey and no my name is not jospeh but jose so whatever... who gives a **** what my nickname is dude...
back to my post, you called 2 people turds when all they did was give good advice for someone who posted a stupid question that shouldn't had been asked in the first place. but they took their time to help out and you put them down, thats just stupid... thats all i wanted to say!!!
Old Feb 11, 2008 | 12:22 PM
joey1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">
well how would you fix it smarty pants</TD></TR></TABLE>
get a new bolt from honda, find the right socket, remove the bolt and replace it with the new one.
if the bolt gets stripped to the point that you can't use the right socket, then you can hammer a smaller one and remove it. if that doesn't help you can try to patiently chisel the bolt loose.
if that doesn't do it then i would use my "mini-ductor" tool to heat up the bolt and then get it loose. i would use that tool only and not the flames from a set of torches since i don't wanna heat the diff housing much...
just a couple of example smarty pants!!!
Modified by joey1320 at 9:36 PM 2/11/2008
Old Feb 11, 2008 | 01:03 PM
street_ruler's Avatar
yah man people are trying to help and you are acting like an ***.
it looks like you ahd the socket on crooked. put a socket on there and put your hand behind it to push the wrench onto the bolt as you turn it. all esle fails you are gonna have to use a bolt extractor biger than god. but a new bolt from honda.
and stop being an ******* or wer are all just going to tell you to use a drill and dont replace the oil
Old Feb 11, 2008 | 01:50 PM
GRAF-FITI's Avatar
* B A N N E D *
que? that's cute josephine....if you boyfriend prefers to call you joey, i understand
i'm also going to assume that he's the quarterback and you're the receiver based on the femininity of your "nickname"....
and who said anything about graffiti? i don't write......
Old Feb 11, 2008 | 02:02 PM
20ls01's Avatar
hes a p.o.s....all his post are garbage. HT would be a better place without him
Old Feb 11, 2008 | 02:08 PM
GRAF-FITI's Avatar
* B A N N E D *
hes a p.o.s....all his post are garbage. HT would be a better place without him</TD></TR></TABLE>
aww why the animosity?
did i call you out on some stupid **** at some point in time as well?
Old Feb 11, 2008 | 03:04 PM
Agent Zero's Avatar
Ok guys... sheesh. I didn't mean to come off like an *******. I was very frustrated yesterday. The person who owned the car before me did a **** poor job of changing the diff fluid. Hens the stripped drain bolt.
if that doesn't do it then i would use my "mini-ductor" tool to heat up the bolt and then get it loose. i would use that tool only and not the flames from a set of torches since i don't wanna heat the diff housing much...</TD></TR></TABLE>
Now this is what I was looking for... Thank you..
aznromeo4u
Feb 24, 2015 02:52 PM
doom26464
Jun 18, 2008 07:10 PM
Mr.Speed
Mar 13, 2008 04:09 AM
dom93hatch
Dec 1, 2004 07:56 PM
RCautoworks
Feb 16, 2003 11:16 PM
