Car bogging when heater is on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">You sure the coolant is bled? </TD></TR></TABLE>To see if air in coolant is responsible for this or not, open the heater valve all the way open(to the hotest position). Run the car this way for a couple of minutes with the fan switch off. If the car bog, try to bleed it again. If the caR doesn't bog, now, turn on the fan. If it bog, see "Boosted_01 R" suggestion. Good luck.
-Chris-
-Chris-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cslegacy »</TD></TR><TR><TD CLASS="quote">hey its still bogging and thats with the heater off so it cant be there its just not as bad with it off</TD></TR></TABLE>
Again.......IS IT BLED PROPERLY? Take the radiator cap off, fill with coolant, turn car on, let run until fan kicks on multiple times, top radiator off, put cap back on, problem solved.
fridexter
Nov 20, 2004 02:52 PM
EGhatched
Mar 14, 2004 04:17 PM
_
