HELP CAR KEEPS GETTING HOT
i just changed my thermostat and water pump.radiator cap. but in the morning after wormed up ill drive down the street and my car will read hot. i just bleed my coolant system but didnt help.
i was thinking about just taking the thermostat off. but how will this affect my car besides taking longer to warm up. will it mess up anything.
Re: (delsolb16)
are you losing coolant? im not talking about leaks, im talking about you adding coolant to the full line, than a couple days later, it's low?
if that's the case, you my friend, have a bad headgasket.
other things you might consider is the temperature sensor and the fan switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolb16 »</TD></TR><TR><TD CLASS="quote">will it mess up anything.</TD></TR></TABLE>
it wont really mess it up. as you said, it'll just take longer to warm up
grammer nawzi
Re: HELP CAR KEEPS GETTING HOT (delsolb16)
[QUOTE=delsolb16but in the morning after wormed up ill drive down the street and my car will read hot.[/QUOTE]
Not sure what "wormed" means, but that can't be good. Do a compression test and see if it's your head gasket, if not, sounds like it might be your radiator.
Re: HELP CAR KEEPS GETTING HOT (sicky)
oops sorry about the "wormed" but i just did a coolant flush and no i dont have to keep on adding water. but i just took out the thermostat and it runs to cold, which will mean that it will run rich. ya i dont want that. whats the lowest temp thermostat they sell.
4DRmafia
02-03-2005 11:40 AM
