Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
NAPA UCA's
Old Feb 10, 2008 | 11:11 AM
Matt_L's Avatar
Default NAPA UCA's
Has anyone had any experience road racing with NAPA's adjustible front upper control arms? They provide + - 1.5 of camber adjustment through the ball joint. Wondering how these will hold up.
If anyone has any better suggestions let me know, but I prefer a control arm with replacable ball joints (ball joints only last me 2 race weekends)
Old Feb 10, 2008 | 12:18 PM
JDM_JNKY's Avatar
Default Re: NAPA UCA's (Matt_L)
Mfactory is the only way to go!
Old Feb 10, 2008 | 12:49 PM
Matt_L's Avatar
Thanks, but MFactory does not make front UCA's for my car, I should have mentioned it is an 88 CRX.
Old Feb 10, 2008 | 01:20 PM
JDM_JNKY's Avatar
Default Re: (Matt_L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt_L &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, but MFactory does not make front UCA's for my car, I should have mentioned it is an 88 CRX.</TD></TR></TABLE>
ouch...go w/ what you got then.
Old Feb 10, 2008 | 03:53 PM
Lo-Buck EF's Avatar
Default Re: (JDM_JNKY)
you would need the vision ucas (havent seen them in a few years) or try the OPM upper balljoints. the napa ones are huge and will hit the top of the fender well for sure on a racecar.
Old Feb 10, 2008 | 06:07 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt_L &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone had any experience road racing with NAPA's adjustible front upper control arms? They provide + - 1.5 of camber adjustment through the ball joint. Wondering how these will hold up. </TD></TR></TABLE>
+/- 1.5?
Are they meant for providing normal alignment adjustments, or for people with lowered cars?
I never heard of an OEM-style adjustable UCA.
-Chris
Old Feb 10, 2008 | 07:47 PM
FlyZlow's Avatar
If your UBJs are only lasting you 2 race weekends, then your car is probably too low or perhaps your front springs are too soft. Something is definitely wrong there. Anyway, I don't know of anyone using NAPA adjustables (didn't know such a thing existed), but I've seen several people use the Skunk2 UCAs with adjustable ball joints and they seem to hold up pretty well if you follow the modified mounting instructions.
Old Feb 10, 2008 | 08:09 PM
tom_l's Avatar
http://www.jhpusa.com/catalog/...53d8f
not sure if they go negative though.
Old Feb 10, 2008 | 09:19 PM
jdm civic 2000's Avatar
Default Re: NAPA UCA's (JDM_JNKY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_JNKY &raquo;</TD></TR><TR><TD CLASS="quote">Mfactory is the only way to go!</TD></TR></TABLE>
how is Mfactory the way to go,when they havent even released any versions of their UCA's?
Old Feb 10, 2008 | 09:41 PM
vietnameeh's Avatar
cause its hella JDM? hahaa
Johnny Mac's Avatar
Default Re: NAPA UCA's (jdm civic 2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm civic 2000 &raquo;</TD></TR><TR><TD CLASS="quote">
how is Mfactory the way to go,when they havent even released any versions of their UCA's? </TD></TR></TABLE>
I'm sure he's tried, Skunk2, Omni, Revo, Vision, and any others I missed to conclude that Mfactory was somehow superior. I'm not saying anything about Mfactory's UCA because I haven't used it, but I do know that for the most part the other UCA's (aforementioned) work fine if properly installed. The only weak part that I can see in any aftermarket UCA's is the ball joints are typically not quite as good as the Honda OEM units.
Old Feb 11, 2008 | 01:52 AM
Matt_L's Avatar
Default Re: NAPA UCA's (tom_l)
My car goes through a lot of front end parts(ball joints, tie rods, etc), but I don't think it is because of my setup, and even if it was I wouldn't change it because I have the fastest Honda on the grid. I think that my 225's coupled with a bumpy track are to blame. I am just looking for a cost effective adjustible UCA that I can simply replace the ball joints on instead of the whole arm. I have installed aftermarket ball joints on OEM Honda UCA's, but it is a pain.
2.6lrex
Feb 11, 2012 04:55 AM
S2000Forsale
Honda S2000
Feb 20, 2006 09:59 AM
iNetForce
Apr 1, 2004 07:15 AM
CRX Lee
10
Feb 27, 2004 11:10 AM
TurboFryBox
Apr 23, 2003 10:51 AM
