ITR started blowing smoke
Old Feb 10, 2008 | 06:12 AM
ITR32's Avatar
Default ITR started blowing smoke
Well heres what happening. I have a mostly stock ITR never smoked but burned a little oil when in vtec but if your driving out of vtec alot oil was fine. I got JDM header test pipe lightened flywheel and ported head. Not until I got a p28 made for ITR that I got some blueish smoke. What should I check first sensors go to a high flow cat. Is there anything else that needs to be changed along with the obd2 to obd1 ecu. I just bought a hondata s300 so it will be tuned soon but any input would help.
Old Feb 10, 2008 | 06:35 PM
ericlee303's Avatar
Doesn't blue smoke mean bad rings?
Old Feb 10, 2008 | 07:06 PM
redline32's Avatar
Default Re: (ericlee303)
could be the rings, I would also check the head make sure vale guides, seals, and seats are all good,,since the headwork was the last thing you upgraded..my .02
Old Feb 10, 2008 | 07:23 PM
401tuner's Avatar
blue smoke means hes burning oil, dosent necessarily mean his rings are bad
TheBook
Mar 30, 2013 02:30 PM
PnoyGS-R
Nov 1, 2010 12:45 PM
codyb13
Jun 16, 2005 08:47 AM
4dohs4mohoes
Aug 4, 2003 08:39 PM
Cyber ITR
Jan 7, 2002 05:10 PM
