compression test
I think its low, what motor do you have, and is it stock? What i mean with all the static c/r and stuff is: I have a z6, i think the stock c/r is 9:1.1 and if i did a comp test my #'s should be 17-20 times that. So they should be between 153-180. To me around 170-180 is good (for my motor). Do you burn oil? How many miles are on it, that tells a lot too.
its fine for that engine. if its the stock engine for a 93 civic, chances are that it has a lot of miles and probably burns some oil. for them to be low like that, but all pretty much the same, then you have a healthy engine considering its age.
also depends on what compression tester you use. different testers give different results. Did you go to autozone and get the cheapest one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziaticvang »</TD></TR><TR><TD CLASS="quote">am i suppose to open my throttle up for a compression test though?</TD></TR></TABLE>
Yes, and the engine should be warm.
kPa = kilopascals (metric unit of pressure)
mugenhatchie
Apr 3, 2006 12:31 AM
