compression test
Old Feb 9, 2008 | 04:20 PM
aziaticvang's Avatar
Default compression test
so what do you guys think about my compression test on my civic dx, 148 on all 4 cylinders, is this good
Old Feb 9, 2008 | 04:32 PM
z6hatchboy's Avatar
Default Re: compression test (aziaticvang)
What pistons do you have? Its good that their consistant, butt it seems low for a stock motor. comp #'s sould be 17-20 times your static c/r.
Old Feb 10, 2008 | 01:15 PM
Default Re: compression test (z6hatchboy)
well i dont really know what you mean but uhh, all i know is that my compression is about 148 lbs psi. so its pretty low for a compression test huh?
Old Feb 10, 2008 | 02:55 PM
z6hatchboy's Avatar
I think its low, what motor do you have, and is it stock? What i mean with all the static c/r and stuff is: I have a z6, i think the stock c/r is 9:1.1 and if i did a comp test my #'s should be 17-20 times that. So they should be between 153-180. To me around 170-180 is good (for my motor). Do you burn oil? How many miles are on it, that tells a lot too.
Old Feb 10, 2008 | 02:59 PM
Hardedge's Avatar
Knowing the engine is important. If I had compression results like that on a B series VTEC I'd be horrified, whereas it might be acceptable for a different motor within a certain mileage range.
Old Feb 10, 2008 | 08:17 PM
it is a d15b7 engine and everything on it is stock...
Old Feb 10, 2008 | 08:31 PM
Mugen112's Avatar
its fine for that engine. if its the stock engine for a 93 civic, chances are that it has a lot of miles and probably burns some oil. for them to be low like that, but all pretty much the same, then you have a healthy engine considering its age.
also depends on what compression tester you use. different testers give different results. Did you go to autozone and get the cheapest one?
Old Feb 10, 2008 | 10:23 PM
ddd4114's Avatar
Default Re: (Mugen112)
Old Feb 11, 2008 | 07:27 AM
i am not quite sure on what kind of compression tester but uh there is only lbs psi and kpa x 100 and i have no idea what kpa is
Old Feb 11, 2008 | 07:29 AM
Default Re: (ddd4114)
am i suppose to open my throttle up for a compression test though?
Old Feb 11, 2008 | 10:09 AM
ddd4114's Avatar
Default Re: (aziaticvang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziaticvang &raquo;</TD></TR><TR><TD CLASS="quote">am i suppose to open my throttle up for a compression test though?</TD></TR></TABLE>
Yes, and the engine should be warm.
kPa = kilopascals (metric unit of pressure)
drave
Nov 21, 2010 01:55 PM
lude98SH
Dec 18, 2006 04:39 PM
mugenhatchie
Apr 3, 2006 12:31 AM
92integraVTECgsr
Jul 17, 2005 02:23 AM
sdinteg
Feb 1, 2005 07:52 PM
