Whats the Maximum boost i can go on my 99 si (Still original pistons)?
Old Jul 3, 2002 | 01:20 PM
CiViC SiR's Avatar
Default Whats the Maximum boost i can go on my 99 si (Still original pistons)?
hi guys ...
Old Jul 3, 2002 | 01:24 PM
POLLO's Avatar
Default Re: Whats the Maximum boost i can go on my 99 si (Still original pistons)? (CiViC SiR)
Properly tuned a/f ratio I say 10 to 12 psi, there are other variables to consider but if the car is daily driven, and would like to keep it reliable I woudln't go any higher. Remember reliability and longevity are 2 different things.
[Modified by POLLO, 5:24 PM 7/3/2002]
Old Jul 3, 2002 | 01:26 PM
CiViC SiR's Avatar
Default Re: Whats the Maximum boost i can go on my 99 si (POLLO)
is 12 psi save on the track only and for daily use 7.5 psi
Old Jul 9, 2002 | 12:38 PM
CiViC SiR's Avatar
12 psi ???!!
Old Jul 9, 2002 | 12:46 PM
p0oty's Avatar
Default Re: Whats the Maximum boost i can go on my 99 si (CiViC SiR)
Sure you can run 12psi, for a short SHORT while.
[Modified by p0oty, 3:47 PM 7/9/2002]
Old Jul 9, 2002 | 01:20 PM
Viorent GRIP!'s Avatar
I say 10 to 12 psi,and would like to keep it reliable I woudln't go any higher. Remember reliability and longevity are 2 different things.
10 to 12 psi on stock internals? have fun, hope you have more $$$$
Old Jul 9, 2002 | 01:21 PM
vtecvoodoo's Avatar
Future Texas Boy
8lbs.
Old Jul 9, 2002 | 02:11 PM
Dr. EKology's Avatar
Default Re: Whats the Maximum boost i can go on my 99 si (vtecvoodoo)
boosting 12 on stock internals on a b16 is a gamble, if i were you i would do 6 psi daily, and 10 psi at the track, maybe one run with 12 but it will probably do some damage. Good luck!
Old Jul 9, 2002 | 02:12 PM
DragII's Avatar
25 Year Member
Default Re: Whats the Maximum boost i can go on my 99 si (EKology)
I'm @10psi w/ stand alone ecu....I wouldn't go any higher w/ out upgrade.
Old Jul 9, 2002 | 02:13 PM
eccentric.ek's Avatar
Default Re: Whats the Maximum boost i can go on my 99 si (DragIIDigital)
dood if u going to boost, boost high how about 15? lol
Old Jul 9, 2002 | 02:39 PM
blufke's Avatar
Default Re: Whats the Maximum boost i can go on my 99 si (redUSDMhb)
get a decompression headgasket...greddy,hks,inlinepro
Old Jul 10, 2002 | 07:34 AM
gokuson's Avatar
Default Re: Whats the Maximum boost i can go on my 99 si (blufke)
high compression = not alot of boost. Prob 6 lbs will b safe. 12 lb will b pushin it.
use low compression pistons, and thicker head gasket, and u can use more boost. 15+
blacc_ej1
Apr 8, 2009 03:21 AM
Nextelbuddy
Oct 10, 2003 10:50 PM
lsvtec101
Jul 30, 2002 07:43 AM
HondaCutter
Jun 1, 2002 11:36 PM
azn_outlaw
Dec 14, 2001 10:39 AM
