Car wont start (H22 in '97 civic)
Old Feb 8, 2008 | 03:44 PM
peter17212's Avatar
Default Car wont start (H22 in '97 civic)
hey everybody.. i just put in the H22 in the Civic Hatchback and it wont start... that same engine was in there before but i rebuilt it and swaped it back in and it just wont start.... the main relay was clicking but i replaced it with a new one but it still wouldn't start....
Please help!!!!!!!
Old Feb 8, 2008 | 03:48 PM
ke98248's Avatar
Default Re: Car wont start (peter17212)
What kinda ECU are you using?
Are you getting spark from the plugs?
Is your fuel pump priming?
Old Feb 8, 2008 | 04:05 PM
peter17212's Avatar
Default Re: Car wont start (ke98248)
I am not sure what kind of ECU it is cuz it came with the car when i got it.... i went and bought the spark tester (the one with little bulb in ther) and it seemed to be flashing when i tried to started.. and the fuel seemed to be priming cuz i can hear it when i turn the egnition on and its shows 40psi at the guage
Modified by peter17212 at 5:21 PM 2/8/2008
Old Feb 8, 2008 | 04:25 PM
z6hatchboy's Avatar
You mentioned it was rebuilt, its probably the timing.
Old Feb 8, 2008 | 04:28 PM
peter17212's Avatar
Default Re: Car wont start (z6hatchboy)
I checked the timing and it is fine.. both the Mechanical and the egnition.... i did menaged to start it for a little bit and then it would just die but now it wont even start at all....
Old Feb 8, 2008 | 04:36 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
double check your map sensor connector and tps?? i think.... they have the same connector and if you mix them up the car wont start, or will start and run like straight ***
Old Feb 8, 2008 | 04:40 PM
peter17212's Avatar
Default Re: Car wont start (oneludesol)
now i tried switching those and it is still the same ...
Old Feb 8, 2008 | 04:41 PM
z6hatchboy's Avatar
Check tps and map as stated before, also try giving it gas in various positions and cranking it.
Old Feb 8, 2008 | 04:45 PM
peter17212's Avatar
Now i also forgot that i was missing couple fuses form the fuse box and so i went bought them and replaced them and i tought that that was the solution.. but when i went to started it seemed like it wanted to start for a second and then same thing but now when i put the fuses and when i try to start the main relay make the clicking noise......... and its a new relay too
Old Feb 8, 2008 | 04:47 PM
z6hatchboy's Avatar
When you switched the tps and map did you get a code?
Old Feb 8, 2008 | 04:48 PM
peter17212's Avatar
no it didn't... no codes just when i switch them then the main relay starts buzzig until i unplog the plug from the map sensor.
Modified by peter17212 at 8:30 PM 2/8/2008
EX goose EX
Jul 20, 2013 11:44 PM
peter17212
Mar 30, 2009 07:40 AM
accord-h22
Feb 20, 2007 04:19 PM
y0whuddupb
31
Aug 9, 2006 01:16 PM
