Car wont start (H22 in '97 civic)
hey everybody.. i just put in the H22 in the Civic Hatchback and it wont start... that same engine was in there before but i rebuilt it and swaped it back in and it just wont start.... the main relay was clicking but i replaced it with a new one but it still wouldn't start....
Please help!!!!!!!
Please help!!!!!!!
Re: Car wont start (ke98248)
I am not sure what kind of ECU it is cuz it came with the car when i got it.... i went and bought the spark tester (the one with little bulb in ther) and it seemed to be flashing when i tried to started.. and the fuel seemed to be priming cuz i can hear it when i turn the egnition on and its shows 40psi at the guage
Modified by peter17212 at 5:21 PM 2/8/2008
Re: Car wont start (z6hatchboy)
I checked the timing and it is fine.. both the Mechanical and the egnition.... i did menaged to start it for a little bit and then it would just die but now it wont even start at all....
GDD's Dr. Phil?
Re: Car wont start (peter17212)
double check your map sensor connector and tps?? i think.... they have the same connector and if you mix them up the car wont start, or will start and run like straight ***
Now i also forgot that i was missing couple fuses form the fuse box and so i went bought them and replaced them and i tought that that was the solution.. but when i went to started it seemed like it wanted to start for a second and then same thing but now when i put the fuses and when i try to start the main relay make the clicking noise......... and its a new relay too
no it didn't... no codes just when i switch them then the main relay starts buzzig until i unplog the plug from the map sensor.
Modified by peter17212 at 8:30 PM 2/8/2008
y0whuddupb
31
08-09-2006 01:16 PM
y0whuddupb
07-31-2006 01:45 PM
