Bad injectors?
Old Feb 8, 2008 | 02:04 PM
freddysEF's Avatar
Default Bad injectors?
would bad injectors cause a miss fire ones the car is fully warm up?
Old Feb 8, 2008 | 04:07 PM
freddysEF's Avatar
Default Re: Bad injectors? (freddysEF)
anyone know
Old Feb 8, 2008 | 04:11 PM
ke98248's Avatar
No.
Old Feb 8, 2008 | 04:27 PM
z6hatchboy's Avatar
Check the wires, plugs, rotor cap, and button. The simple things.
Old Feb 8, 2008 | 04:40 PM
freddysEF's Avatar
Default Re: Bad injectors? (z6hatchboy)
i did everything and did a tune up, plus i redid my timing and adjusted my valves because they were off and its miss firing on 3 and 4 only when the car is fully warm up (97 civic hx)
Old Feb 8, 2008 | 04:43 PM
z6hatchboy's Avatar
Did you make sure the plugs were gapped correctly? Also, make sure the wired are seated good.
Old Feb 8, 2008 | 06:13 PM
hall97civic's Avatar
stop what you are doin. If it is a 97 hx, you need to do the following. Either take it to a dealer and tell them that your egr plenum is plugged up and they need to clean it because it should still be under warrenty(emissions) or you can clean it your self. It isn't hard. TAke off your fuel rail. Take out injectors. REmove plenum cover (I think like 4 10mm bolts), it is directly next to the egr valve and below the fuel rail. My car was getting random missfire and it was running lean because when it is up to temp is when the egr valve opens and becasue the computer measures the amount of exhaust gas that recycles, it leans the fuel a little bit. If you want to make sure that is is the plenum then you can unhook your egr valve and run it. You will obviously get a cel for the egr valve, but if it stops misfireing then it is probably the plenum. The plenum is a maze of small passages and it gets plugged full of carbon. This is what was wrong with my 97 hx and it took me two weeks to figure it out. I did the tune up and everything else and this is what it ended up being. Mine started out as a misfire of 2 and 3 cylinders. Then eventually got the code for all of them, but 3 and 4 were the most common. I also got a code and wrote it down, but it was not in the honda shop service book. I lost the code and can't remember what it was. if you want to talk to me in person, pm me.
hoxsie323
Honda CR-V & Element
12
Apr 2, 2013 09:02 PM
mikester1222
17
Apr 18, 2008 07:32 PM
thesmogman
Jan 8, 2007 03:43 PM
BB1vtec
May 20, 2006 09:32 AM
Muckman
Sep 17, 2003 08:27 PM
