WELDING IN CAGE?
Old Feb 7, 2008 | 12:08 PM
SiKnezzX408's Avatar
Default WELDING IN CAGE?
Where's a good place of welding a 6 pt cage in the back of the rear end of hatchback EG or CRX ? I want to know if there's a preference of welding the rear cage pipes to the back on the chassis part or on the wheel well near the shock tower. I tried looking for info, but no results. Also pictures would be nice of rear cage weld in those places I'm talking about. I know nhra rules shows needed to be welded with plate,but in a import where would it be best welded at!
Old Feb 7, 2008 | 12:13 PM
NH538DB8's Avatar
Especially in an import 6 inch square plate must be used.
Old Feb 7, 2008 | 12:39 PM
Default Re: (NH538DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NH538DB8 &raquo;</TD></TR><TR><TD CLASS="quote">Especially in an import 6 inch square plate must be used.</TD></TR></TABLE> thanks already know that!
Old Feb 9, 2008 | 08:44 AM
drhonda's Avatar
I'd like to know as well.
Old Feb 9, 2008 | 02:47 PM
Default Re: (drhonda)
isn't it better to weld the plate on the chassis than to make on near the rear shock tower on crx? anybody please respond guru fabricators
Old Feb 10, 2008 | 04:01 AM
Civic89stdB16's Avatar
Default Re: (SiKnezzX408)
i want some pics of a 6 point welded into an ef hatch for when i do mine.
Old Feb 10, 2008 | 08:15 PM
Default Re: (Civic89stdB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 &raquo;</TD></TR><TR><TD CLASS="quote">i want some pics of a 6 point welded into an ef hatch for when i do mine.</TD></TR></TABLE>
Old Feb 11, 2008 | 09:13 AM
CagedRuss's Avatar
I build a box, it meets and exceeds the 6"x6" plate rule. I do them for both Road Race and drag Race cars. Sometimes I will make them less than a box with round edges depending on what the customer is doing.
I like attaching the plate/box to the uni-body frame rail and shock tower. Everybody has their opinion on what is best.
Old Feb 11, 2008 | 09:24 AM
Default Re: (CagedRuss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CagedRuss &raquo;</TD></TR><TR><TD CLASS="quote">I build a box, it meets and exceeds the 6"x6" plate rule. I do them for both Road Race and drag Race cars. Sometimes I will make them less than a box with round edges depending on what the customer is doing.
that's nice. I've also seen people have a bar straight across both the shock tower, and then weld both rear pipes on the straight bar. let me see if I can find pictures!
Old Feb 11, 2008 | 04:21 PM
CagedRuss's Avatar
I did not find it necessary since I use an "X" between the rear support tubes.
Old Feb 12, 2008 | 08:08 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKnezzX408 &raquo;</TD></TR><TR><TD CLASS="quote">that's nice. I've also seen people have a bar straight across both the shock tower, and then weld both rear pipes on the straight bar. let me see if I can find pictures!</TD></TR></TABLE>
That's not the right way to do it. Bars should meet at the ends, never in the middle of another bar. This puts too much stress on the side of the bar and can cause it to fail. The pic up above is what you want to do.
Old Feb 12, 2008 | 12:15 PM
Default Re: (nonsense)
thanks for the info.
15to1
Aug 2, 2006 12:47 PM
rasinhell
May 8, 2005 09:41 AM
T--Rex
13
Dec 2, 2004 10:11 AM
Sampsonite987
16
Mar 30, 2004 04:33 PM
JDMBOLONI
14
Apr 22, 2003 08:29 AM
